Nordschleife
- Joined
- 6 Mar 2014
- Messages
- 22,176
Just done the modification to have both rear fog lights on my car (instead of just the driver's side).
Before I start, credit goes to GT4 for telling me how to do it.
All in took about an hour to do and £2.79 for some single core wire from Maplin.
First remove the 2 rear light units (no need to disconnect) and let them hang on the sides of the rear bumper like so
Then on each side, cut some of the sheath off the grey wire running to the fog light (outer one) like so (ignore the black single core hooped over it)
Thread the single core wire through one of the holes behind where the light unit sits and then thread across the back of the car under the bonnet lock and through one of the holes at the other side
Then cut the single core wire to length ensuring you've left the same amount of slack at the wiring harness.
Solder each end to where the grey fog light wire has the sheath cut back like so
and tape up with insulation tape
Then pop the light units back in - job done.
Off and on shots
IMHO much better with both fog lights on rather than just the one side and safer as well on a foggy night incase one bulb pops. :thumbs:
Off and on shots
