The clicking gets quicker as the car gets quicker. If i stop, it stops. If i shift into neutral and rev the engine, the sound does not occur.
I had a clicky-rear-axle in my old 350z (apparently a common quirk with them). Is this a likely issue with the 996T?
A few Rennlist threads suggest CV Joint re-grease or possibly something loose inside a hollow spoke alloy or maybe even a valve-cap not seated fully and so clicking as it 'slips' each time the wheel rotates.
I've checked the vales any they seem tight, so I'm guessing maybe a CV joint? (Or maybe something is loose inside an alloy?) Anyone else ever had this happen?
