Hi All,
Im currently looking at a 996 Turbo, its an '03 model, got 76k on the clock. Has a pretty well documented history, mainly OPC and last with an Indy (HD Motorsports???).
Seller says clutch has been done, discs and pads are ok.
The car is offered at a not too unreasonable price, but can anyone offer any advice or warning signs with whats been mentioned above that i should be aware
Thanks in advance
- Bad points seller explains are Heat shield bolts need replacing - could this be something worse being hidden here?
Leather looks a bit tatty and drivers bolster and seat edge (where getting in an out) looks a bit flattened.
Passenger window - problem with mechanism
Interior light switch broken
Has aero kit front splitter/ spolier which looks (IMO) awful so id like to fit a stock - is this easy?
Has a single CD no nav or cruise - is it easy to fit a PCM unit to make it look stock?
Thanks in advance
