997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
joewhite2417
PostPosted: Tue Apr 05, 2016 9:34 am    Post subject: Reply with quote
Here's my info Alex...
date inputted: 05/04/16
member: joewhite2417
model: 9962 C4
engine size: 3.6
purchase date: June 2015
date registered: Sept 2001
mileage (at purchase): 78000
mileage (now): 81000
bearing (orig./replacement): Original
failure data (if applicable): IMS failed 27/2/16
comment: Failure occured at low speed pulling away from lights. Dramatic power loss evident but no noise initially. Bag of spanners on restart.
PostPosted: Tue Apr 05, 2016 11:53 am    Post subject: Reply with quote
Thank you.
Ursa911
PostPosted: Thu Apr 21, 2016 10:00 am    Post subject: Reply with quote
Here’s my info. Didn’t want to post earlier as if might tempt fate and I’m superstitious like that
date inputted: 21/04/16
member: Ursaminor1
model: 996.2 C4S
engine size: 3.6
purchase date: 29/09/14
date registered: 23/01/04
mileage (at purchase): 106000
mileage (now): 111000
bearing (orig./replacement): Original - to my knowledge
comment: Last service Indy said all ok clean and no concerns. Cut open oil filter and no particles found.
"If you see the tree you are driving in to, you have under steered. If you only hear it, you have over steered." - Walter Röhrl
2004 996.2 Manual C4S Cab Arctic Silver - Ursa911
thekman
PostPosted: Tue Apr 26, 2016 4:07 pm    Post subject: Reply with quote
Hi here is my info..
date inputted: 61/04/16
member: thekman
model: 996 C4S Cab
engine size: 3.6
purchase date: 25/09/15
date registered: 01/09/2004
mileage (at purchase): 38577
mileage (now): 40183
bearing (orig./replacement): Original until now
comment: Currently the engine is out owing to power steering failure. Had IMS and RMS checked, both showing some signs of oil so having both replaced as a precaution.
G3BML
PostPosted: Mon May 23, 2016 9:06 pm    Post subject: Reply with quote
date inputted: 23/05/2016
member: G3BML
model: 996.2 C4S
engine size: 3.6
purchase date: 17/09/2015
date registered: 02/01/2003
mileage (at purchase): 50400
mileage (now): 54300
failure data (if applicable): N/A
comment: Carried out two oil changes since owning the car, inspected oil filter. No signs of metal in filter.
PostPosted: Mon May 23, 2016 9:10 pm    Post subject: Reply with quote
thumbsup
Surfrider
PostPosted: Thu May 26, 2016 10:16 am    Post subject: Reply with quote
Date input: 26/05/16
Member: Surfrider
Model: 996 C4S
Engine: 3.6
Purchase Date: 28/09/2007
Date Registered: 01/04/2002
Mileage (at purchase): 24,197
Mileage (now): 102,108
Bearing (orig/replacement): Replaced at 39,328 as preventative maint. with clutch change.
Failure Data: None
Comment:
2002 C4s
ragpicker
Estoril
PostPosted: Thu May 26, 2016 3:27 pm    Post subject: Reply with quote
Ragpicker
986 Boxster S
3.2 M96
Registered 2000
Mileage at purchase 132500
Bearing - original in replacement engine. Engine replaced Feb 2002 due to IMS failure at 25k miles
996GAZ
PostPosted: Fri Jul 08, 2016 9:36 pm    Post subject: Reply with quote
Purchase 04/2016
Built 2001/2002
996 c4s manual
115,000m
good service history with RMS change last year
Original IMS said to be fine
original engine, no rebuild
touch wood...still pulling like a train!
stevepen
PostPosted: Sat Jul 09, 2016 7:42 am    Post subject: Reply with quote
Purchased March 2016
Built 2000
994 C4
80k miles
Original engine no rebuild
2000 C4 Tip
PostPosted: Sat Jul 09, 2016 11:11 am    Post subject: Reply with quote
Members - your data will not be used if all data required is not given, as stated in the 1st post. Please can you update with the correct data.
stevepen
PostPosted: Sat Jul 09, 2016 4:41 pm    Post subject: Reply with quote
Updated sorry Sad
date inputted: 08/07/16
member: stevepen
model: 9961 C4
engine size: 3.4
purchase date: 26/04/16
date registered: 01/03/00
mileage (at purchase): 77200
mileage (now): 80290
failure data (if applicable): None
2000 C4 Tip
C4pperS
PostPosted: Sat Jul 09, 2016 5:29 pm    Post subject: Reply with quote
Date input: 09/07/16
Member: C4pperS
Model: 996 C4S
Engine: 3.6
Purchase Date: 28/03/2016
Date Registered: 01/04/2004
Mileage (at purchase): 79,600
Mileage (now): 81,300
Bearing (orig/replacement): As far as I'm aware original
Failure Data: None
Comment: Still going strong thumbsup
thumbsup
Gurmot
PostPosted: Sat Aug 06, 2016 7:40 am    Post subject: Reply with quote
Date input: 06/08/16
Member: Gurmot
Model: 996 C2 tip
Engine: 3.6
Purchase Date: 31/07/2016
Date Registered: 05/07/2002
Mileage (at purchase): 67,500
Mileage (now): 68,000
Failure Data: None
Comment: having an inspection at a local specialist in a couple weeks. They have already recommended replacing the IMS at a cost of £1300 plus vat. Very interested in this thread as I am inclined to get it done but still not sure.
July 2002 C2 Tiptronic with M030.
PostPosted: Sat Aug 06, 2016 8:07 am    Post subject: Reply with quote
Save your money. If you do decide you want to change a perfectly good bearing for an unknown one, the best replacement would be a standard off the shelf bearing for around £30 and to have the job done, budget around a few hours labour. Whoever quoted you £1300 + VAT is ripping you off with an inferior product, unless of course they're talking about removing the engine, stripping it and replacing the IMS assembly with the later 997.2 design shaft, in which case would be a bargain.
Gurmot
PostPosted: Sat Aug 06, 2016 9:03 am    Post subject: Reply with quote
They told me they would need to remove the engine but I didn't check on the extent of the work. I will ask before I do anything, and this thread has been enormously useful in helping me understand the issue and weigh up the probabilities of failure. The cost of failure is still unclear but if it could be £10k plus I may have the IMS sorted for peace of mind. I will chew it over.
Chris_in_the_UK
Estoril
PostPosted: Sun Aug 07, 2016 2:19 pm    Post subject: Reply with quote
Gawd - how on earth can they diagnose the need for a (very overpriced) IMS bearing without inspecting the car?
(Welcome - nice to see you here BTW).
2006 Cayman S PCCB's
Niall996
PostPosted: Sun Aug 07, 2016 4:53 pm    Post subject: Reply with quote
They probably read Total911
PostPosted: Sun Aug 07, 2016 4:55 pm    Post subject: Reply with quote
Floor
Goto page Previous  1, 2, 3 ... 18, 19, 20, 21, 22  Next
Page 19 of 22
