Hi - I'm after some advice,
I've managed to nick the oil pipe second from bottom coming out of the oil tank during a horrendous day removing black tar type underseal from the o/s rear wheel arch.
I'd used a steamer and scraper for this first round and got nowhere, so three angle grinders later finally managed to get to fresh metal in readiness for a repaint, all part of of a home chassis leg fix.
The pipe is now trickling oil out slowly which means I can't have the arches painted until I can rectify and I don"t think I can stem the leak with a temporary repair.
The pipe is a very cheap plastic flexi pipe almost like cable trunking. It disappears into the inner wheel arch and the depths of the car.
The car is due an oil change anyway so losing the oil during the switch is not a problem, but can anyone identify what this pipe is and how much grief I'm in for in the replacement? I'm thinking its a recovery to a local indie as I'm not putting the car back together just to take it apart again for the paint guy once this has been fixed!!
The pipe does look a little fragile, the power sander must have just caught it and created a nick in the flexible bend.
Thanks in advance to those who can help advise me!
