997 : 2004- 60
Boxster : 1997- 24
Cayman : 2005- 20
Gibbo205
PostPosted: Sun Sep 25, 2011 10:27 pm    Post subject: Decided to change the oil myself - WOW how easy!!! Reply with quote
Hi there
Well when I got my C2S in March this year, I had all the work required to pass the 111 point check done by Mike at S&C, plus some extra work, new plugs, new coils and an oil change, at this point the car was on circa 30,000 miles.
Its previous service was at 24,000 in April 2010, so certainly at no point due yet.
On the 911, well its rear engine makes life very easy, especially on my driveway and onto doing the oil change I am amazed as to how easy it was. I drained the oil warm, then put through 1/2 litre of fresh oil to make sure all the old was out, which in honesty looked pretty clean anyway, but the car is on just over 35,000 miles, so its only been in their 5000 miles max.
Some pictures:-
Oil draining:-
Filter tool for easy removal:-
I then decided to disect the old filter and check for metal particles as its rumoured this can be an early detection of an IMS failure, needless to say upon pulling my filter apart I was happy to be unable to find anything, so fingers crossed looks like my IMS is all good, here is a picture of the filter dismantled:-
I shall be taking my car for its Porsche service in March/April 2012 which will mean since my ownership the car is getting fresh oil circa every 5000-6000 miles, maybe this is a bit ***** especially considering I have warranty, but my view is oil is less money than an engine and a whole lot less stress. I like to look after my cars and if I can help prevent a failure by doing a couple of oil services between the set Porsche services I will. Smile
Plus its my oppinion that 20,000/2yr intervals is too long and could be why 997.1 had a few engine failures as the protective properties in oils I suspect don't quite last so long but I'm not an oil expert. Still for the price of oil makes sense to just change the oil more regular, 10l can be had for sub £80 so its not huge amounts of cash.
GT4
Nordschleife
Nordschleife
PostPosted: Sun Sep 25, 2011 10:30 pm    Post subject: Reply with quote
Good work Thumb
Glad the filter was clear.
michelin
2006 Porsche 997 Carrera 2
PostPosted: Mon Sep 26, 2011 7:30 am    Post subject: Reply with quote
I do exactly what you do but also put it in the dealer for its service too. Good hint re .5 L through to get rid of old oil, I'll do that next time.
What are peoples thoughts on changing the antifreeze? I do realise its lifetime but new fluids, surely, cant harm !
Current:
Porsche 981 S PDK Fully Loaded, beautiful.
Former:
Porsche 911 997.
Audi A4 B7 2.0T FSI S-Line.
BMW E36 318iS Coupe.
Ford Escort RS Turbo Series 2.
Ford Fiesta XR2 MKII.
GT4
Nordschleife
Nordschleife
PostPosted: Mon Sep 26, 2011 7:44 am    Post subject: Reply with quote
Imdont change my own oil, but then my car only does 1,700 miles between OPC services.
I do, however, request they retain the filter for my perusal.
As for lifetime coolant, I interpret that as 4-5 years max (although almost clockwork rad perforation probably means even Porsche view it as this sort of timescale too!).
Gibbo205
PostPosted: Mon Sep 26, 2011 7:54 am    Post subject: Reply with quote
Mike did my coolant flush/change when he fitted the centre X51 radiator. Smile
Also I still do let Porsche service it as well when its due, I just change the oil myself in between them seeing it, they also know this and are fine about it. I guess they would be though, less chance I will be claiming under warranty, LOL.
black911
PostPosted: Tue Oct 04, 2011 9:58 pm    Post subject: Reply with quote
going to get my oil changed, I just hit the 80k mark now, man I spend more time driving than working, I have done around 10,000 in a month hahah so I need to get my plugs changed over so will have the plugs n oil done same time i guess.
you actually reminded me Smile
Car collection
204 bhp - Porsche boxster 2.5
221 bhp - Mercedes S320
343 bhp - BMW M3 e46 convertible
??? bhp - Porsche 996 c2 (from oakley design)
343 bhp - BMW M3 e46 coupe (current)
??? bhp - Porsche 997s coupe (current)
Martian
2007 Porsche 997 Turbo
PostPosted: Tue Oct 04, 2011 10:44 pm    Post subject: Reply with quote
I've changed the engine oil myself twice now and the gearbox oil once. Very straight forward and nice knowing that it has actually been done!
Manheller Racing - Nürburgring
black911
PostPosted: Thu Oct 06, 2011 10:25 am    Post subject: Reply with quote
Hi what is the best oil for the carrera S.
Porsche tell me 0w40 and another tells me 10w40? any ideas?
also Porsche want £280+vat to change oil and filter and wont even stamp my book as its not something they claim to do as a seperate job.
Car collection
Martian
PostPosted: Thu Oct 06, 2011 10:54 am    Post subject: Reply with quote
I use Motul X-Max 8100 0W/40. It's a higher spec than Mobil 1 and cheaper too.
http://www.opieoils.co.uk/p-68993-motul-8100-x-max-0w-40-high-power-petrol-and-diesel-engine-oil.aspx
Gibbo205
PostPosted: Thu Oct 06, 2011 11:11 am    Post subject: Reply with quote
I am sure its fine but its not Porsche approved.
Look at this one:-
http://www.opieoils.co.uk/p-877-motul-8100-x-cess-5w-40-petrol-and-diesel-fully-synthetic-engine-oil.aspx
Look at the approvals and any oil you buy needs to have this:-
•Porsche A40
Now I am sure its not a requirement, but as there are quite a few which are Porsche approved I'd advice you still with those.
GT4
Nordschleife
Nordschleife
PostPosted: Thu Oct 06, 2011 11:21 am    Post subject: Reply with quote
0w40
Unless you have forgotten to mention something pertinent.
Latest approved list:
http://www.911uk.com/download.php?id=20725
Martian
PostPosted: Thu Oct 06, 2011 11:23 am    Post subject: Reply with quote
Gibbo205 wrote:
...I am sure its fine but its not Porsche approved......
Lots of things which are higher spec/quality than standard never get the Porsche approved moniker.
Michelin Pilot Super Sports aren't Porsche approved (yet), but it doesn't stop OPC's selling them and the Experience Centre using them!
And the approved viscosity for a Carrera is 0W/40, not 5W/40.
black911
PostPosted: Thu Oct 06, 2011 11:32 am    Post subject: Reply with quote
I agree, I no longer take the word of Porsche, I would rather take advise from a porsche specialist thats why I am just going to book her in and have a major done, its about 10k miles to early but my plugs are due and my oil could do with changing so £250 + vat for the oil and filter and £175 + vat for the plugs, makes it better for a full major at £420 + vat through strasse that do the oil and filter and plugs and a full service.
Plus they are going to fit my k&n and my new throttle body and plenum when its made and I fancy a trip to ewood park anyhow to the blackburn rovers club shop Very Happy
Car collection
Gibbo205
PostPosted: Thu Oct 06, 2011 12:49 pm    Post subject: Reply with quote
Agreed.
Both 0W-40 and 5W-40 are both approved Porsche viscosity's I believe or at least thought? And 5W-40 can be better suited so engines with more miles, something Baz/Hartech went into great detail explaining and some will tell you 0W-40 is better.
Either way they are both approved and fine to use. Smile
I know of some putting 10W-60 in their engines, I'd not personally and neither is it approved but again they don't seem to have issues, but this is GT guys I see mainly doing this which suggest to me no doubt due to more track use so they use that grade for more protection up top.
black911
PostPosted: Thu Oct 06, 2011 1:27 pm    Post subject: Reply with quote
have my car booked in next week for full service ect.. but my oil shows flashing on the bottom notch, so put 1 L in before and no change~? got to wait 1 hour to check again, any ideas on this how to reset it and surly 1 litre would make some change?
Car collection
Ekona
PostPosted: Thu Oct 06, 2011 1:53 pm    Post subject: Reply with quote
Unless it's more than 1L below the minimum mark, of course...
When was the last time you checked it and how many miles have you done since?
Dan
Ex-997.2 C2S PDK
markiii
PostPosted: Thu Oct 06, 2011 1:59 pm    Post subject: Reply with quote
when I did mine last month
997.1s
It took just over 7 litres before the display even showed minimum level.
thereafter it took 0.5 litres between bars
if a litre does make a difference chances are your quite low to start with
black911
PostPosted: Thu Oct 06, 2011 2:00 pm    Post subject: Reply with quote
last service was on time and my next service is due in 10k miles.
Only noticed it low when I put key in a few days ago.
Car collection
black911
PostPosted: Thu Oct 06, 2011 2:09 pm    Post subject: Reply with quote
£19 per litre, I mean I have no issue with the price, but its getting replaced next week so I dont want to spend to much on 1 week if you know what I mean, I will go get another litre and stick it on
Car collection
markiii
PostPosted: Thu Oct 06, 2011 2:41 pm    Post subject: Reply with quote
for the sake of a week you can get away with mixing it, but better cheap oil than no oil
Goto page 1, 2, 3  Next
Page 1 of 3
