Creaking Clutch
Seagull
22 Aug 2005
3,657
Gave the car a bit of a run today - about 200 miles - and I noticed that every time I push the clutch padal in or out, there is a creaking sound. It sounds a bit like a rusty spring being stretched.
As I only had the clutch replaced a couple of weeks ago, should I be worried? Have they done something wrong or failed to lubricate something?
Migration info. Legacy thread was 58933
mine was creaky before i had the clutch changed - they replaced the clutch slave cylinder and it no longer creaks...............not sure if this helps you.........
Migration info. Legacy thread was 58958
I also have the same problem, clutch creaks. Creaks more when the cars hot.
I had a brake fluid changed recently and on the C4 993 the fluids are somehow linked ! as they recommend bleeding the clutch after Brake fluid change. Wondering whether could be the reason !
Migration info. Legacy thread was 65400
My mondeo does this, but its the seats creaking as my legs move!
Migration info. Legacy thread was 65427
It's at times like this when I'm glad I have a tip!
Migration info. Legacy thread was 65430
I had these symptoms on my 993 - creaking when hot weather and a large increase in pedal pressure required with a jerky pedal action.
Get a friend to push the pedal and try to locate the source of the noise - if its by the pedal its the cylinder - if its at the rear (gearbox) its possibly the clutch release bearing (thats what mine was - at 20k miles).
I would take it straight back to the people who did the job.
Migration info. Legacy thread was 65450
124,586
1,441,759
49,011
Mchass
