997 : 2004- 61
Boxster : 1997- 26
Cayman : 2005- 20
Cayenne : 2003- 4
allan harryman
PostPosted: Sat Jan 03, 2004 10:25 pm    Post subject: Reply with quote
German registered 1992, white, no sunroof or rear wiper! How do i tell U.K headlamps from continental ones, can I get new scale for speedo or new unit required ( for mot )? Manual in German, where can i get U.K copy, but need to know how to check oil, most dry sumped engines need to be running, does this apply? Also ! light needs reset on each start up, any ideas? ( All guages fine ) Gearbox now sorted (Synchro). ***** me... are tyres expensive!
Migration info. Legacy thread was 12152
Toby Armfield
PostPosted: Sun Jan 04, 2004 6:54 pm    Post subject: Reply with quote
You should be able to order a uk manual from an OPC for a 964 still, my UK 993 manual has all left hand drive pictures in it - just english text!
You can get face stickers for the speedo to change them to mph but the trip clock will still be in km. There may be a speedo for sale still on pistonheads or e-bay for a 964.
Hope that helps
Migration info. Legacy thread was 12160
Chris H
PostPosted: Tue Jan 06, 2004 9:31 pm    Post subject: Reply with quote
for your speedo, get hold of the '911&Porsche World magazine'... They always have loads of good seconds and new bits advertised...For oil checks, yes you need to have the engine running and at normal running temperature..The difference between the high and low level is 1.5 litres... Some will say that the oil level indicator (inside the car) is not the most acurate of beasts, i have always found mine to be spot on... Ignore any acurate reading before the engine is at normal temp..
Enjoy your 964.. Mine has been a dream..
Migration info. Legacy thread was 12264
