997 : 2004- 63
Early 911 : 1964-1977 2
Cayman : 2005- 23
Macan : 2014- 7
40Anni996
PostPosted: Tue Dec 03, 2019 10:38 am    Post subject: Battery Dead - CTEK question Reply with quote
I keep my battery on trickle charge via a CTEK MXS 5.0 as I sadly don't get to drive it very frequently.
Woke up to a sunny Sunday last weekend and excitedly jumped in for a spirited drive only to find the battery not able to turn the car over and to add insult to injury I was then deafened by the alarm going off in the garage. I tried a couple of CTEK regenerations on it over the weekend but it keeps tripping out at stage 5 (according to the manual this means the battery won't hold a charge).
I have a Bosch S5 010 in the car which is around 5 years old. I know these cars are hard on batteries but it did surprise me a little that the battery has gone this quickly when it's always been kept on trickle charge.
I'll buy a replacement but my question is this; could it be the way I'm charging the battery that has led to its unexpectedly short life?
Until a year or so ago I used to charge it via the ciggy lighter socket but after a couple of episodes of the CTEK dropping out I figured it might be more reliable to switch to charging via the battery terminals in the front. Easy enough to leave the clips on the terminals permanently and just pop the frunk lid and unplug the extension cable each time I take the car out.
The CTEK manual instructs charging via battery + and - terminals and looking at the 996 FAQ on battery issues it seems others also charge this way, but digging around I have found a PH post which says you must use an earthing point rather than the battery negative or you're likely to reduce the life of the battery as you miss out the 'little black box' that provides feedback on the status of the battery to the charging source. Is this true for the CTEK MXS 5.0 does anyone know or is it clever enough to not require this? Could connecting directly to the terminals have contributed to my battery's (relatively) short life?
2004 996 C2 40th Anniversary
I have a keen eye for derail
PostPosted: Tue Dec 03, 2019 10:50 am    Post subject: Reply with quote
Personally I reckon 5 years on a battery that's hardly been charged by use is pretty good. Dont know
40Anni996
PostPosted: Tue Dec 03, 2019 10:58 am    Post subject: Reply with quote
Thanks T8. So charging through driving > trickle charging from a battery's perspective? Gives me another good reason to drive it more frequently...
don0301
PostPosted: Tue Dec 03, 2019 11:03 am    Post subject: Reply with quote
Hello
I have no experience with 911's BUT:
I have an Audi RS6 ("smart" battery in the boot) and this car must be charged (trickle charged) by terminals in the engine bay, not on the battery terminals. The reason given is the car "monitors" current use and therefore the battery must not be charged etc directly whilst in situ.
If your car is similar this may be the likely problem. Does your handbook advise?
My previous car was 13 years old when sold still on first battery, my Audi is now 11 years old and the same. I use a CTEK 5 also, but normally only boost charge/condition it sometimes a year.
Hope this helps.
40Anni996
PostPosted: Tue Dec 03, 2019 11:16 am    Post subject: Reply with quote
Thanks don
I have no access to the handbook at the moment but will check it later
moorhouse
PostPosted: Tue Dec 03, 2019 11:20 am    Post subject: Reply with quote
40Anni996 - I have experienced very similar problems with a CTEK dropping out of its cycle and showing the error light on my 40th AE - initially it seemed fine but then started to go to about No 4 and then throw a wobbly. Tried it with both the cigarette lighter connection and direct to the battery and same issue. However the more clunky Halfords one is just fine (direct to battery terminals) and does the same smart charge job as far as I can see. The CTEK charger seems to work fine with my other older "classic" cars so don't think it's the CTEK charger itself - maybe there is something in the car circuit that the charger is sensing and throwing a fault. Not aware of any differences electrical wise between the 40th AE and the standard 996 though. Any electronics experts out there can probably advise. Also interested in any answer to the best connection to the negative side if not the terminal itself.
Cheers..Ian
40th Year Anniversary #698
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Tue Dec 03, 2019 12:14 pm    Post subject: Reply with quote
No idea... but my battery is at least 5 yrs old, and has been kept on trickle charger through the lighter socket when in the garage and has shown no signs of letting go. Not a CTEK though, its an Airflow.
That said, I did have a battery go on a 4S a while ago which I used daily for long trips. Drove 90 mins to work, hopped into it at lunchtime, battery dead.
40Anni996
PostPosted: Tue Dec 03, 2019 12:17 pm    Post subject: Reply with quote
Thanks Ian, sounds like a very similar experience. I'll order a new battery anyway but think I'll try the CTEK one last time on this battery via an earthing point to see if it still throws a wobbly. I need to find a long term solution to keeping the new battery in good shape!
chicb
PostPosted: Tue Dec 03, 2019 12:20 pm    Post subject: Reply with quote
If your car has a battery management system ie stop/start, if connecting to the battery, only the pos+ should be connected & the neg- should be connected to a body earth ie a screw etc. Without stop/start, + & - are ok
If your battery has gone so low as you say you need to use an old fashioned charger to get the volts up as ctek will not bring back a dead battery, then connect ctek & it will then optimise the charge & care. My F type which only did 200miles this year has ctek on constantly & starts on the button.
Possibly you have a dead cell then its a new battery.
moorhouse
PostPosted: Tue Dec 03, 2019 1:50 pm    Post subject: Reply with quote
Like I said, I have been using a Halfords brand "smart" charger (which in principle seems to do pretty much the same as the CTEK type) until a couple of weeks ago - always went through the charge sequence fine and then sat as expected on the top up mode. Just changed recently to the one supplied with a Carcoon as I needed the Halfords one for another vehicle and the Carcoon one had been sitting in the box doing nowt. It seems to be working fine as well - again, it's classed as a "smart" charger so has a sequence of lights then a steady one when its in maintenance mode.
Still non the wiser why neither of my CTEK 5 chargers work on the 911 when they are absolutely fine with every other battery/vehicle I have. It's like something on the car circuitry stops it from going through the sequence.
Cheers...Ian
freshy
PostPosted: Tue Dec 03, 2019 4:06 pm    Post subject: Reply with quote
You are not alone, I have exactly the same issue with CTEK 5 on my 911, when it is fine on other cars!
I would love to figure out why...
2005 996 'C4S Plus' Cab Manual in Atlas Grey X51
40Anni996
PostPosted: Tue Dec 03, 2019 5:21 pm    Post subject: Reply with quote
Thanks freshy - tis odd indeed.
Any joy using another type of ('smart') charger/maintainer?
Thinking of pulling the trigger on a cheap Chinese one from Amazon to try instead of the CTEK.
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Tue Dec 03, 2019 5:24 pm    Post subject: Reply with quote
My Lidl £15 one is doing a great job so far...
alfazagato
PostPosted: Tue Dec 03, 2019 6:29 pm    Post subject: Reply with quote
I use a charger made by Granite Digital in CA. Save-a-battery is the trade name and it does just that.....highly recommended.
freshy
PostPosted: Wed Dec 04, 2019 10:05 am    Post subject: Reply with quote
I'm in a similar boat, just being more cautious before I buy another charger as thought I was buying the best when I bought the c-tek!
I'll update this thread before I buy something, maybe its a 996 MY04 thing? Question
40Anni996
PostPosted: Wed Dec 04, 2019 11:12 am    Post subject: Reply with quote
Or maybe it's an X51 thing?
40Anni996
PostPosted: Wed Dec 04, 2019 12:42 pm    Post subject: Reply with quote
don0301 wrote:
Hello
Hope this helps.
Just checked the handbook and all it says about charging is to disconnect the battery cables first. This MAY be because of the reason you state for your Audi but it doesn't explicitly say why the advice is to remove the cables. Not really much help for constant trickle charging either Dont know
moorhouse
PostPosted: Wed Dec 04, 2019 12:56 pm    Post subject: Reply with quote
Nor does it explain why some chargers work (even when just connected to the in-situ battery terminals) while the CTEK doesn't. I've sent an e-mail to CTEK HQ with a link to this thread to see if they have any technical comments.
See what they come up with.
This is why I'm automatically suspicious of any car with more than 4 fuses and three wire colours.
Cheers..Ian
Giff
PostPosted: Wed Dec 04, 2019 8:14 pm    Post subject: Reply with quote
The S5 refers to the warranty - 5yrs, Bosch S3 - 3yrs.
If its under 5yrs old and you can remember where you bought it..
997.2 C2
911UK
Porsche Community
Porsche Community
1997 Porsche 993 Carrera 2
PostPosted: Wed Dec 04, 2019 10:02 pm    Post subject: Reply with quote
After 2 failed Porsche Ctek units in 8 years, have bought the Noco Gernius G7200 7.2 amp which I can't so far fault
also with it's AGM mode, good at charging the Cayenne's large stop/start battery
it's much larger but if I consider it's important, then it was about time for an upgrade
they also have the smaller NOCO Genius G3500UK 6V/12V 3.5 Amp charger
FOLLOW 911UK ON TWITTER
