997 : 2004- 64
Cayman : 2005- 22
Macan : 2014- 8
Jonathon555
PostPosted: Mon Jan 19, 2015 7:42 pm    Post subject: Which child seat and stroller fit ? Reply with quote
Went down to halfords to get a child seat for my car for my son, soon to be 9 months old. They shook there heads and said nothing fits.
Need a group 1 seat and also a recommendation for a buggy that can fit my car.
Non isofix
996 Turbo manual
997.2 C2S manual
E46 m3 manual
And others .....
medicus
PostPosted: Mon Jan 19, 2015 8:26 pm    Post subject: Reply with quote
there are plenty that will fit (google it) but they are not approved, or "fit properly" except for the porsche dedicated ones from the OPC
we had murders trying to get a good fit, and did indeed settle for a britax from halfords, because it was the smallest/slimmest,
however not the safest or best quality, it really is hard as lets be honest, a 911 is not a family car, i use the britax only when i must, and take extra care with my cargo.
also its prudent to remove the velcro seat bottom for a better fit, due to the shape of the 911 seat bottom.
as far as strollers go....good luck with that, if you have a 2 wheel drive, you might be able to find a collapsable one, but we couldnt, if you have a 4 wheel drive, then no way at all.
it will have to lay across the rear footwell, or you could do as we did, and buy a cayenne GTS also. (lol)
Steve B
PostPosted: Mon Jan 19, 2015 8:35 pm    Post subject: Reply with quote
I have a C4s and a Quinney Zapp pushchair fits in the boot without any problem.
Car seat wise the Maxi Cosi Pebble fits in fine without removing the rear seat base. The front seat has to be quite far forwards but my wife still fits in relatively comfortably.
Steve
2003 Cobalt Blue Porsche 996 C4S
Jonathon555
PostPosted: Mon Jan 19, 2015 8:38 pm    Post subject: Reply with quote
Steve
Is the pebble a group 0 seat ? Rather than a forward facing group 1
996 Turbo manual
997.2 C2S manual
E46 m3 manual
And others .....
Nosillad
PostPosted: Mon Jan 19, 2015 9:30 pm    Post subject: Reply with quote
I have a C4S and use a Britax Evolva 1-2-3 plus.
We had the lovely lady from mothercare fit 3 different seats into the back before we bought one and by the time we finished half the shop were out watching and agreed it was the best fit.
I have my daughter in the front and back with it and whilst it's a bit of a fiddle it's not that hard to get in and out
It's forward facing and suitable for 9-36kg only problem is it doesn't recline, but then we don't do long journeys so never been much of a problem
Haven't taken any of the seat cushions out either
2004 -Porsche 996.2 C4S
medicus
PostPosted: Mon Jan 19, 2015 9:58 pm    Post subject: Reply with quote
yep, thats the same seat i use, but i found it to be a better fit without the seat base in, but my 911 does not have a rear seat bulkhead like yours, because its a hatchback.
pj_sibley
PostPosted: Tue Jan 20, 2015 6:58 am    Post subject: Reply with quote
As stated above, the Quinny Zapp and Zapp 2 both fold down small enough to slip perfectly into the frunk of a C2. Perfect!
As for car seats, the Maxi Cosi Opal seat reported to be approved for the 911 when I last looked (check the Maxi Cosi website to be certain) and is both rear and forward facing. It covers a range of ages/weights. However, I found it to be a tight fit in the 911 and it was a bit too upright, even with the OE seat base removed. We now use a slimline Britax seat on the rare occasions that we need/want to, which works well.
SOLD - 2003 Porsche 996.2 C2 Targa Tiptronic S
mikem7709
PostPosted: Tue Jan 20, 2015 9:26 am    Post subject: Reply with quote
I use an old Porsche Junior fix in mine (the Grey Group I/II) fits perfectly in the bucket seats or the seat hollows in the back (I have rear seat belts fitted).
The new BMW/mini seats are the same but can be bought without isofix which makes them much lighter to thread into the back. The Mini one also comes in a plainish Black finish.
Steff
PostPosted: Wed Jan 21, 2015 2:02 pm    Post subject: Reply with quote
Out of interest, do most baby seats fit in the front seat fine? I'm assuming you can switch off the airbag?
Literally just picked my 98 C2 up on monday and havent had a chance to have a proper play yet!
steff
chimp911
2011 Porsche 997 Turbo S
PostPosted: Wed Jan 21, 2015 2:43 pm    Post subject: Reply with quote
It depends on the seat as the side bolsters may be too narrow for some child seat bases. As for deactivating the airbag then this may be more of a problem - see here for more info http://www.911uk.com/viewtopic.php?p=552446
If you already have one of these (passenger side) then you are in luck:
Otherwise I'd speak to your local OPC about a possible retrofit - HTH Thumb
stubbsy
PostPosted: Thu Jan 22, 2015 10:40 am    Post subject: Reply with quote
I posted a similar thread a while back when I deciding on practicality of keeping my Porsche with new born arrival imminent - don't know about rating but I was recommended the recaro Young sport for +6 months
I kept the Porsche and have taken my little one out a couple of times, I have the easy fix base in there with a maxi cosi pebble seat, passenger has to sit a bit further forward but it does work and as the travel buggy I have the wuinny zapp which. Fits perfectly in the turbo boot😀😎
coopertrooper2001
PostPosted: Thu Jan 22, 2015 12:32 pm    Post subject: Seat Reply with quote
Maxi Cosi Tobi fits well - I bought this from Halfords (with their help).
Recaro Young Sport has a high risk of buckle crunch. Halfords called Recaro whilst I was there and they (and Halfords) did not recommend the seat for the 911.
toohey
PostPosted: Thu Jan 22, 2015 4:47 pm    Post subject: Re: Seat Reply with quote
second vote for the maxi cosi tobi - i took the seat back out and then fettled the fit onto the seat base using folded dust sheets to make it sit nice and straight. Our 14 month old loves it! Thumb
NumberoftheBeast
PostPosted: Fri Jan 30, 2015 12:00 am    Post subject: Reply with quote
+1 for the Quinny Zapp. On our second now (got the one with the detachable seat; think it's the Zapp 2 or Plus)
We have a baby seat that would fit for the baby. Gonna stick it on eBay soon because our son has outgrown it.
911 Turbo X50
Fiesta ST turbo (Mountune 215)
Golf R DSG
Solidwoodsmith
PostPosted: Tue Sep 24, 2019 7:57 am    Post subject: Reply with quote
If you want to have a baby trend jogging stroller then this one is perfect. It offers many great features and due to many great items, it is considered as the preferred selection of parents. It has got a tray which is capable of placing two cups in it. Moreover, it is really easier to move as it is the light weight stroller. Parents can easily carry it wherever they want as it is easy to connect with car seats. Baby Trend Expedition Bubble Gum Review
