997 : 2004- 65
996 : 1997-2005 33
Cayman : 2005- 22
Macan : 2014- 8
kul997
PostPosted: Sat Aug 10, 2019 9:44 am    Post subject: 997 AC & Fan On start up - Passenger mirror not moving d Reply with quote
When iput the key in the ignition the Fan & AC start up at full speed. Very annoying as I have to then re-set the controls.
I suspect there is a way to programme the PCM some how. Also, when selecting reverse gear, the passenger mirror does not move down anymore.
I have no idea what has happened, these worked well before.
Any advise please??
Poker2009
PostPosted: Sat Aug 10, 2019 10:28 am    Post subject: Reply with quote
The knob to adjust the mirrors must be pointing towards passenger one, for the mirror to go down in reverse. It took me a long time to work that one out!
Or could be something else, like a vehicle handover using PIWIS.
997.1 C2S, Black, Coupe, 6-Speed Manual, Ohlins R&T.
Millers NT+ 10W50, driven above 3000 RPM.. original engine.
kul997
PostPosted: Sat Aug 10, 2019 10:42 am    Post subject: AC Fan & Passenger Mirror Reply with quote
Many thanks! I'll give it a try.
PostPosted: Sat Aug 10, 2019 3:32 pm    Post subject: Reply with quote
It sounds like it's stuck in defrost mode ?
Is the button sticking perhaps ?
i think a tester connected a look is best along with a vehicle handover .. not a fault i've seen before .
kul997
PostPosted: Sat Aug 10, 2019 5:34 pm    Post subject: Passenger mirror and Reverse gear Reply with quote
Sorted !!
It worked. The mirror adjustment switch has to be kept on passenger mirror for it to go down when reversing.
Thanks.
