997 : 2004- 60
Boxster : 1997- 27
Cayman : 2005- 22
NedHan79
PostPosted: Sun Feb 24, 2019 7:44 pm    Post subject: Air con delete Reply with quote
Has anyone dumped their air con?
Mine dosnt work and it’s something I hardly ever use anyway.
I like the idea of getting rid of the condensers for radiator air flow reasons.
What’s involved?
Is there a smaller belt available if I remove the pump?
Is there any other problems that come with it?
Will my dash instruments still blow cold air, as in like a car with no air con, and will the heat be affected in any way?
Marky911
PostPosted: Sun Feb 24, 2019 11:07 pm    Post subject: Reply with quote
Madman!
That is all.
NedHan79
PostPosted: Sun Feb 24, 2019 11:09 pm    Post subject: Reply with quote
I don’t seem to be getting a good reception with this idea mark.
Maybe it’s a sign Question
Marky911
PostPosted: Sun Feb 24, 2019 11:12 pm    Post subject: Reply with quote
Just kidding Ned.
Rich ELA covered it in his thread and I think Martin maybe leaving it off, I can’t remember.
Yes a smaller belt is available.
I’d just sort it though. We are lucky that our model is the cheapest 911 to fix the aircon on. Even if you require a new compressor they’re cheap on eBay.
Try fixing a 964/993 system, you’re into thousands. Surprised
Even in a GT3 Clubsport the only option I couldn’t live without would be aircon.
Colour coded centre console is nice too mind, although easy to do. Wink
PS It’s all down to the use you have in mind. No wrong or right way. Thumb
NedHan79
PostPosted: Sun Feb 24, 2019 11:17 pm    Post subject: Reply with quote
For all the car does, I don’t need to be in any panic. I can simply slide it down the list a little.
Or maybe a lot. It’s a big list Surprised
Martin996RSR
PostPosted: Mon Feb 25, 2019 2:59 pm    Post subject: Reply with quote
I took my compressor off because it broke and was heavy(6KG). I did notice the difference, but I am a driving nerd. I left the pipes and rads in place as they aren't all that heavy and I wanted to keep it easy to reinstate. I tie wrapped bags over the exposed pipe ends in the engine bay in order to keep out dirt and moisture.
The shorter belt is easy to get hold of and fit. I looked at the smaller pulley but research showed the gain is too small to be measurable, so I didn't bother.
benbuhagiar
2008 Porsche 997 Carrera 2
PostPosted: Mon Feb 25, 2019 3:17 pm    Post subject: Reply with quote
My aircon is always on and I wouldn't buy a car without it.
You are a mad man!
997.2 Carrera PDK
Martin996RSR
PostPosted: Mon Feb 25, 2019 3:40 pm    Post subject: Reply with quote
My car is a weekend B road basher only, no commuting apart from early morning school runs of a couple of miles before the day has had a chance to warm up. If I was stuck in traffic every afternoon I would certainly re-install it.
NedHan79
PostPosted: Mon Feb 25, 2019 4:36 pm    Post subject: Reply with quote
I’ll b lucky if I do 2000 miles a year so I’m not worried if it works or not.
It’s purely a toy.
Can you remember where you got the belt?
coullstar
PostPosted: Mon Feb 25, 2019 5:11 pm    Post subject: Reply with quote
Ive done 6000miles in mine with non working pump and smaller belt and it's fine to be honest. There a handful of days when I'd wanted it.
I will fix it but I don't think it's a total necessity IMO.
crash7
PostPosted: Mon Feb 25, 2019 5:15 pm    Post subject: Reply with quote
I have modified my a/c system to run with one condenser to get additional airflow to the rad.
That said I ran most of last summer without the a/c so am currently contemplating ditching it.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Mon Feb 25, 2019 5:21 pm    Post subject: Reply with quote
Me too.
NedHan79
PostPosted: Mon Feb 25, 2019 6:38 pm    Post subject: Reply with quote
I have been watching your progress mc. Nice job.
I’m thinking of ditching the lot. Strip it out and have done with it.
It’s good to get different opinions on the subject but I think it’s a done deal.
Where did you get the belt mc?
coullstar
PostPosted: Tue Feb 26, 2019 9:07 am    Post subject: Reply with quote
Only thing you may have to watch is the car possibly running tool cold then, do you have a Low temp thermostat fitted? If you read up on that its a good thing to have to get the coolant circulating at an earlier temp.
My worry would be that fully exposed rads would then mean the car is over cooling compared to normal. I will fix mine at some point but I suppose the way I thought about it was that if the condensers are there they are protecting the rads a bit and it never runs hot anyway. You would need to rip everything out to make a difference IMO and you do have to think about resale if it occurs as it may put a lot of people off.
MisterCorn
PostPosted: Tue Feb 26, 2019 9:14 am    Post subject: Reply with quote
I am still running AC in mine, so using the standard belt. It is just that I have gone from 2 condensers down to 1. It was possible to spec the car without AC so there shouldn't be a problem with it running too cool. Note that when AC is on the fans are always running, so pulling more air through the radiators anyway. Without AC the fans would be off unless needed.
Mesh over the bumper openings to protect the radiators, otherwise muck just gets trapped between the condensers and radiators and blocks airflow through both.
Martin996RSR
PostPosted: Tue Feb 26, 2019 10:11 am    Post subject: Reply with quote
Here you go Ned:
https://www.design911.co.uk/fu/prod179/Drive-Belt-for-cars-WITHOUT-Aircon-Porsche--996-986-99610215165/
NedHan79
PostPosted: Tue Feb 26, 2019 10:24 am    Post subject: Reply with quote
Thanks guys.
I have a whine so I’m assuming it’s the pump. I’ll maybe just whip it out and go from there. I. Any imagine there’s too many cars specced without air con but like I said earlier, I have a sunroof so I’m not too worried about it.
If it runs to cold I’ll just fix it and stick it all back in
Thanks for the link for the belt Martin. I was assuming it was going to be some over expensive modified parts.
maldren
PostPosted: Tue Feb 26, 2019 10:56 am    Post subject: Reply with quote
Don't underestimate how hard it is to get the pump out/in. The rear bolt is tricky and you need to take the air temp sensor out, I couldn't get it back into the grommet, had to get help....
Mike
NedHan79
PostPosted: Tue Feb 26, 2019 11:12 am    Post subject: Reply with quote
Ok. I haven’t actually had a chance to look at it yet but. I don’t want to get side tracked from the other bits I need to finish first.
Do the bolts hold anything else?
Martin996RSR
PostPosted: Tue Feb 26, 2019 12:39 pm    Post subject: Reply with quote
I don't remember what else I had to remove, but I'm pretty sure it was just the airbox. I'm sure it's pretty simple and could be done comfortably in less than an hour, including fitting the new belt and putting the airbox back in.
