997 : 2004- 58
Boxster : 1997- 27
PostPosted: Fri Jan 11, 2019 7:44 pm    Post subject: Reply with quote
thinking
Indy Mechanic .
ballcock
1996 Porsche 993 Carrera 2
PostPosted: Fri Jan 11, 2019 7:56 pm    Post subject: Reply with quote
... Worried now Grin
Ex. '99 996 C2 manual coupe.
PostPosted: Fri Jan 11, 2019 7:57 pm    Post subject: Reply with quote
A 996 does tend to raise the idle when the a/c is turned on .. 997 and it tends to be pretty stable .
This is basically a pre map setting .. the car is told there is a load on the engine and so raises the idle to compensate.
If yours doesnt do this then you would start with fault codes .. there should be something , or it might be the load of the a/c pump is actually canceling out the rev increase .
Im not sure there is a problem there atm to be honest but i would class it as further inv . req .
Oil pressure of 1 bar is pretty much what any Porsche will acheive on a hot engine .. modern cars have a variable oil pressure control (an oil pump puts a load on the engine ) so it increases engine power by reduceing the pump pressure .
EDIT .. i forgot i was in the 996 section and answered as a 997 question .. deleted and re did it Very Happy
Im old Razz
Indy Mechanic .
ballcock
PostPosted: Fri Jan 11, 2019 9:45 pm    Post subject: Reply with quote
Not as old as my wife tells me I am Razz
P911X50
PostPosted: Fri Jan 11, 2019 9:56 pm    Post subject: Reply with quote
A related question in respect to faulty senders.
1. When turning on the ignition (and not starting the car), my oil pressure needle moves off the bottom and moves to the 0. Is that normal? as I've just recently replaced mine.
2. When cold and driving, it never moves beyond 4. Seems little low to me.
Are both these readings normal
Question
Porsche 996 Turbo X50 with 9e exhaust,
BMW M6 V10,
Previous
Evo 4 with Evo 8 MR Engine 360 bhp - Road Legal Track car
Previous
MR2 Turbo 280 bhp - Road Legal Track Car
Marky911
PostPosted: Fri Jan 11, 2019 10:35 pm    Post subject: Reply with quote
Gauge sounds fine P911.
I was as clear as mud in my other post when I said if it rises off bottom.
I'm picturing bottom as "0".
Ignition on, engine off, gauge should read no more than zero.
4 bar cold pressure sounds a bit low. Mine is at max on cold starts.
ballcock
PostPosted: Fri Jan 11, 2019 11:17 pm    Post subject: Reply with quote
The gauges are all over the place. My pals starts at 5.0 bar on a cold start. Never goes below 2 bar when properly hot.
Mine only goes to 4.5 on cold start, drops to 1 after 20 ish minutes.
And now P911 yours only reaches 4.0 ..
it seems the only thing worth bothering about is the low oil pressure light if it ever appears.
Ghianightmare
PostPosted: Sat Jan 12, 2019 12:51 am    Post subject: Reply with quote
https://m.youtube.com/watch?v=sYUSN3Webrw
2002 Seal Grey C4S
Goto page Previous  1, 2
Page 2 of 2
