997 : 2004- 71
996 : 1997-2005 36
Boxster : 1997- 25
jwb1380
PostPosted: Tue Jan 08, 2019 5:20 pm    Post subject: TPMS Autel MS-Sensors Reply with quote
I'm looking for some feedback on these guys for a 2007 997.1. Wheels are at Exel with Chris and thinking about adding TPMS sensors and don't want to pay Porsche prices!
Anybody used them? Do they need programmed before fitting? Also how does the system work out which sensor is in which wheel?
Comments appreciated!
http://www.autelstore.co.uk/wholesale/autel-mx-sensor-433mhz-315mhz-universal-programmable-tpms-sensor.html?gclid=EAIaIQobChMI78jszNfe3wIVyZPtCh1h_wzGEAQYASABEgI5CvD_BwE
997.1 4S Targa
1967 Morris Cooper S
Cervelo R5 with 303's
PostPosted: Tue Jan 08, 2019 7:13 pm    Post subject: Reply with quote
Im afraid i know nothing about these sensors but unless im totally wrong then you need one of the tools to actually teach these sensors Dont know
Our market is 433MH btw .
When i fit new Porsche sensors i can either code them on .. which doesnt always work or just fit them and drive the car untill it learns the sensor .. this can be upto 20 miles on a gen 1 system .. gen 2 and its 50 yards .
Again im not sure how this sensor would work when its seems to imply gen 1 and gen 2 versions are supported .. they do Not interchange with porsche ones ..
So im back to the fact that i think you need one of their devices to actually program these .
just my guess work though im afraid .
jl-c
PostPosted: Tue Jan 08, 2019 7:15 pm    Post subject: Reply with quote
I use these, work well no issues https://www.ebay.co.uk/itm/Orange-P429-TPMS-OTO-Wireless-Auto-Locate-Tire-Pressure-Monitoring-System-74-Psi/362208291275?epid=12012730709&hash=item54554be9cb:g:FTkAAOSwlxRaVGQ1:rk:24:pf:0
sorry just re-read your post, mine has no Porsche TPMS Embarassed
Gazc2
PostPosted: Tue Jan 08, 2019 8:11 pm    Post subject: Reply with quote
I got a set of 4 from here previously they were £136 for 4 guaranteed for 3 years I fitted them and the car learned them after a run no problem
https://tpms24.de/content/homepage
The Autel ones you mention have a 2 year guarantee , I just cant see anywhere if they need to be programmed or the car will pick them up might be worth dropping them an E-mail at £17.30 each worth doing a bit of homework at that price
2007 997 Turbo & 924s in progress
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
PostPosted: Wed Jan 09, 2019 12:39 am    Post subject: Re: TPMS Autel MS-Sensors Reply with quote
Is Chris/Exel sourcing them. Question
He fitted replacements at about that price to my 997.1T 3 years ago and they've always worked fine.
I don't know what make they were but they worked within the usual 10 minutes/ few miles.
jwb1380
PostPosted: Wed Jan 09, 2019 10:03 am    Post subject: Reply with quote
Thanks for your comments.
Chris will fit if you supply, he will only source gen Porsche parts although he has fitted these Autel once before.
Can it be that simple to just fit them and they work out the system - self calibrate/communicate?
Worth a go at less than £100 for the set. I sent Autel an e-mail enquiry but no reply as yet.
I'll let you know how I get on...
997.1 4S Targa
PostPosted: Wed Jan 09, 2019 8:04 pm    Post subject: Reply with quote
The sensors send out a wireless signal which the antennas pick up ..
If its the same " launguage " then it will all work fine.
Gen 1 and gen 2 sensors are not .. this system says it can cope hence i think it needs programming some how .
Someone shouting at me in German is not going to get my attention so ill ignore it .. sensor talks German but the car speaks English so its ignored .. programming is the translation req .
Basically i dont know Confused
Matt Seabrook
PostPosted: Fri Feb 08, 2019 10:28 pm    Post subject: Reply with quote
I fit programmable sensors at work. I have not titled the Autel senors as we use a different system and not to a Porsche either. The ones we use need to be programmed to a specific make and model of car. They are the 433Mh sensors like all the new vehicles use but the coding and language for each car are different hence the need to carry out a basic set up on each new sensor. We can either program a blank sensor with the correct protocol and a random I.d. or match the I.d. Off the old sensor. Hope this helps.
997.2 Turbo PDK
