Anti-Roll Bar Bush Replacement
Mr Bacchus
26 Oct 2012
303
Happy new year!
Slightly loaded question...I have a C4, rear anti-roll bar is 18mm diameter but the replacement bushes I am trying to fit have a 15mm hole. Supplier (aftermarket) tells me this is correct and has checked stock and all are the same 15mm diameter.
I tried to fit the parts but lost the first round of the fight as I couldn't get the clamp over the bush enough for the bolts to engage and even begin to compress the rubber.
The current bushes do have a 18mm hole but they are Superpro poly bushes that allegedly have the size for size hole due to difficult to compress the poly.
FYI - I replaced the front bushes a few days ago ( bought from OPC) and from memory the hole was same size as the bar, and that was still a fight. I didn't measure those as there was no obvious difference - unlike he rears.
The supplier is being very helpful and has offered a refund but I'm just wondering if I buy them again direct from OPC will I get the same again.
So, do you think the parts are correct with a 15mm hole?
Steve
I think you should use the correct size bushes as you need the bar to be able to rotate freely in the bush to allow for correct movement of the suspension under load.
The correct part number for your early C4 with an 18mm bar is:
477 411 313B
15mm sounds a bit too small tbh.
477 411 313B
Agree with all of the above. I'm going to buy the parts from OPC and see what I get.
yes get the correct bushes first, minimum size roll bar on the 964 is an 18mm, powerflex do them
124,611
1,442,067
49,045
pazz
