997 : 2004- 64
Boxster : 1997- 26
jond58
PostPosted: Mon Dec 24, 2018 8:15 pm    Post subject: Gear Shift Reply with quote
Finally got round today to installing the gear shifter I purchased earlier in the year. It’s a new 997 one from the OPC. Removed the old metal short shift that had been installed by the previous owner and marked all the cable ends, installed and drives with all gears engaging far less notchy and with a little more distance between shifts but accurate. One query though. When it’s in neutral the shift seems to lie more naturally left if that makes any sense, ie not central. Is this an adjustment issue?? And seen as I have six forward and one reverse does anyone know how or what direction to adjust as I’d like ideally to keep it a six speed!!!
wasz
Paul Ricard
1999 Porsche 996 Carrera 2
PostPosted: Mon Dec 24, 2018 8:42 pm    Post subject: Reply with quote
I have the 997 shifter too and thinks its the best choice.
You can get a tool that holds the lever whilst you adjust the cables to suit.
Otherwise just look which cable adjusts it in the direction you want, adjust and try! One cable does each direction.
jond58
PostPosted: Mon Dec 24, 2018 8:48 pm    Post subject: Reply with quote
I have the green thing, it came with it. I had to pull the left cable to get it back to the mark I had on it but the right one dropped on the mark so logical says maybe pull the right one?!? I just don’t want to be without gears by messing!! The shift is longer with the 997 I bought but much better shifting for me.
PostPosted: Mon Dec 24, 2018 9:46 pm    Post subject: Reply with quote
You've set the lateral cable clamp in the wrong position. 2 min job to set...........without the centre console in. No tool required, just undo the clamp when the car's in neutral, hold the lever in the desired position and re-do the clamp.
jond58
PostPosted: Mon Dec 24, 2018 9:49 pm    Post subject: Reply with quote
Is that the left hand one?!? I’m thinking maybe I shouldn’t have pulled that cable to line up and should have left it to be where it was?!? Gt3 console delete so 7 screws and some clips, fifteen minutes tops to remove the centre console so it’s not a hassle
PostPosted: Mon Dec 24, 2018 9:52 pm    Post subject: Reply with quote
Yeah - the left one Thumb
jond58
PostPosted: Mon Dec 24, 2018 9:55 pm    Post subject: Reply with quote
Ah?!? Silly me! I had them marked up and sort of second checked myself having to pull that one slightly?! Should have trusted my gut instinct and left it where it was!! Oh well a good excuse to escape Christmas and do some tinkering!!!
