997 : 2004- 63
Boxster : 1997- 25
Hooner
PostPosted: Wed Dec 19, 2018 11:59 am    Post subject: Alarm woes, help! Reply with quote
Hi chaps. My car is laying low in the garage for the winter and now the alarm keeps going off for no reason, i have checked the things mentioned in the hand book, now i have disconnected the battery to give us some peace! boy its loud. Any help as to what the problem may be will be much appreciated thanks and Merry Christmas to all.
911 a way of life!
GMG
PostPosted: Wed Dec 19, 2018 5:35 pm    Post subject: Reply with quote
I was messing about with mine in the garage and set the alarm off...nearly deafened me !
GMG
PostPosted: Wed Dec 19, 2018 5:37 pm    Post subject: Reply with quote
...if it's not on a trickle charger then battery might be running low and triggering it?
I leave mine on a CTEK...
Low battery usually triggers alarms.
GMG
Great minds!
Hooner
PostPosted: Wed Dec 19, 2018 6:12 pm    Post subject: Reply with quote
I have ordered a smart trickle charger,so i'll try that, but it seems to beep twice now on locking where as before being layed up all was fine Question
911 a way of life!
asterix_the_gaul
1999 Porsche 996 Carrera 2
PostPosted: Wed Dec 19, 2018 6:49 pm    Post subject: Reply with quote
Check you have not left the centre armrest up, double beep is something left open
Lukec4s
PostPosted: Wed Dec 19, 2018 7:14 pm    Post subject: Reply with quote
As above either an open compartment.. arm rest, glove box, frunk or battery low which sets off alarm. You will know if it is the battery as you won’t be able to start the car. Had that problem recently.
rabbitstew
PostPosted: Fri Dec 21, 2018 11:23 am    Post subject: Reply with quote
Must be that time of year, my alarms started going off randomly atm. It started doing the double beep which would indicate something left open, so I opened/closed everything - doors, bonnet, boot, glove box & central arm rest cubby hole. I thought that had fixed it, as it stopped the double beep, but the alarm still keeps going off randomly. Usually at night though I have to say.
How ive fixed it atm is to press the lock button twice on the key fob, which apparently turns off the internal sensors - so motion, glove box & cubby hole. Fingers crossed its not gone off since, which would indicate some sort of fault with one of those 3 sensors.
Im not sure how I can narrow it down as there are no faults showing in the logs when I check with durametrics.
2008 997.1 Turbo Manual - 585whp thanks to do88 & 9e
Hooner
PostPosted: Fri Dec 21, 2018 12:41 pm    Post subject: Reply with quote
Fully charged the battery and have it on a smart charger now, alarm still goes off even when engine is running, i have now disconnected the siren! my ears have had enough Sad
911 a way of life!
PostPosted: Fri Dec 21, 2018 9:04 pm    Post subject: Reply with quote
Ok .. the first thing to check is whats actually triggering the alarm ..
i would use a tester and look at alarm activations and events .. this will actually tell me what has been faulty when the car was locked and what actually triggered the alarm .
I can also see the positions of every item of the alarm system and see whats faulty .
Basically if you dont have a tester then i would guess at a half hour labour charge to you at an Indy .
This is obviously far cheaper than throwing bits at it in an attempt to fix the fault .
Strangely enough .. it may well be the siren thats causeing this !
Indy Mechanic .
Hooner
PostPosted: Sat Dec 22, 2018 7:34 pm    Post subject: Reply with quote
Thanks guys for the replies, i shall look into getting it tested in the new year. Thumb
911 a way of life!
lofi
2001 Porsche 996 Turbo
PostPosted: Thu Dec 27, 2018 8:24 pm    Post subject: Reply with quote
What is single beep? Mine does this on locking and then at some random interval afterwards the alarm will go off. To stop this I lock then unlock the car, don't open a door and it locks itself after 60 secs and the alarm stays silent.
LoFi
996 turbo tip FOR SALE http://911uk.com/ads_item.php?id=9513
ex 944 2.5 manual
ex 964 C4 manual
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Thu Dec 27, 2018 8:31 pm    Post subject: Reply with quote
I think a single beep is something left open (or a sensor thinks its open) and a double beep is a fault in the system?
lofi
PostPosted: Thu Dec 27, 2018 8:33 pm    Post subject: Reply with quote
Thanks Infra - I was confused by the information that a double beep was something left open. Single beep something left open (which of course it isn't so it is a faulty microswitch I expect).
LoFi
ex 944 2.5 manual
ex 964 C4 manual
Pickse
PostPosted: Thu Dec 27, 2018 8:43 pm    Post subject: Reply with quote
I have had similar issues in the past with my 996.
I've noticed on my car there are two sources of a 'beep'.
The car horn will beep if something is left open, or if I double click to lock and disable the internal sensors.
But sometimes the alarm siren will beep one or twice when locking, apparently randomly and I have yet to find a reason/documentation for these beeps.
Just wondered which 'Beep' the OP is hearing. Horn or Siren?
Pickse
03 Arctic Silver 996T Tip S
Now 9E38 - An improved! 996T
Hooner
PostPosted: Fri Dec 28, 2018 12:53 pm    Post subject: Reply with quote
i t was both,first the horn then the siren, followed by the siren going off in full effect a few seconds later. All seems to be fine now with the smart charger on after a week of charging i shall plug the siren back in and see if it goes off, results to follow. Thumb
911 a way of life!
PostPosted: Fri Dec 28, 2018 4:35 pm    Post subject: Reply with quote
Yup Thumb
Indy Mechanic .
