997 : 2004- 63
Early 911 : 1964-1977 2
Boxster : 1997- 29
Cayman : 2005- 22
Macan : 2014- 7
knw911
PostPosted: Sat Dec 15, 2018 5:05 pm    Post subject: stuck headlight Reply with quote
like many 996's of this vintage, my headlights have yellowed a little. today i chose to tackle them with my DA polosher.
thought it would be easier to do them on a bench... so popped out the passenger side and went to work. all good....however,
went to the drivers side and simply couldnt get it out the car. the retainer bar seems to be spinning and / or the tool spinning on the bar.
any help or ideas folks??
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Sat Dec 15, 2018 5:22 pm    Post subject: Reply with quote
Have you tried a proper (if I recall right) 5 mm socket? The one in the tool kit is not great.
I think it’s a solid bit of metal, so not much to go wrong with the retaining bar.
knw911
PostPosted: Sat Dec 15, 2018 5:36 pm    Post subject: Reply with quote
will try that.. cheers!
Paynewright
PostPosted: Sat Dec 15, 2018 7:09 pm    Post subject: Reply with quote
The tool doesnt work on mine - I use a 5mm deep socket 1/4” drive. Now in the tool kit with a T bar and extension.
Ian
asterix_the_gaul
1999 Porsche 996 Carrera 2
PostPosted: Sat Dec 15, 2018 7:13 pm    Post subject: Reply with quote
I really struggle with the passenger one out, it's easy to get the tool in the drivers side, the passenger side plastic hole surround thing is just off by a mm to unless I really force the tool in dead hard it spins as its not engaged on the hex head.
knw911
PostPosted: Sat Dec 15, 2018 7:30 pm    Post subject: Reply with quote
will try a 5mm tomorrow ... thanks guys
knw911
PostPosted: Sun Dec 16, 2018 1:09 pm    Post subject: Reply with quote
so tried the 5mm socket, same problem in that it isn't releasing the headlight. could the head light have been incorrectly seated last time its been put in? also, the 5mm socket is now stuck (sure will come off with some pilars).
also not great pic, but photo of the polished vs non polished headlights for those interested.
 Filesize:  157.62 KB
 Viewed:  2039 Time(s)
Paynewright
PostPosted: Sun Dec 16, 2018 1:38 pm    Post subject: Reply with quote
Hate to be professor of the bleedin obvious - are you turning the right way. Its the opposite direction to the other side.
Next step is to strip out the arch liner and see if you can budge it from underneath.
Ian
knw911
PostPosted: Sun Dec 16, 2018 1:52 pm    Post subject: Reply with quote
tried both ways.. (so to speak Very Happy hahaha)
PostPosted: Sun Dec 16, 2018 4:45 pm    Post subject: Reply with quote
Last check before pulling the linner down is have a look in the hole where the adjustor is .. sometimes the bar is at an angle and the tool wont go on it .. ive angled the tool before and pushed to get it on in the past .
Indy Mechanic .
ragpicker
Reims
PostPosted: Sun Dec 16, 2018 4:51 pm    Post subject: Reply with quote
These light trays are a great design when they work, but as they get older and brittle they're a nightmare.
The passenger side one in my Boxster has broken where the bar inserts so it can't snap the light into place. Its now held in by zip ties until I get around to putting the replacement tray in. Thats a bit of a pain to do too, hence why I've kept putting it off Rolling Eyes
knw911
PostPosted: Mon Dec 17, 2018 3:41 pm    Post subject: Reply with quote
When a tool (porsche supplied or 5mm socket) is put on the retainer bar, you can feel it spin, but it "spins off".
What I can't figure out is if it ...;
a) the Bar end which the tool connects to has been worn away, effectively taking the edges off the bar meaning the tool spins
Or..
b) the bar is spinning underneath the headlight
And when I say spinning, i dont mean freely. It gets to a point where there is a bit of friction, then it slips, and spins.
Attached are a couple of pics. My fear is A.
 Filesize:  105.38 KB
 Viewed:  1862 Time(s)
 Filesize:  89.56 KB
911munKy
PostPosted: Mon Dec 17, 2018 4:33 pm    Post subject: Reply with quote
If it’s ‘A’ you could clean up the area and using a strong glue (JB Weld) attach an old 5mm socket. That way when the glue has set, usually 24 hrs, you could use an extension bar to turn it.
2000 C2 996
asterix_the_gaul
PostPosted: Mon Dec 17, 2018 6:46 pm    Post subject: Reply with quote
It looks perfectly centred so it's not the problem with it not being able to engadge due to off centre hex. I can see the hex looks OK, not rounded, but there's a load of grease over it? It's an odd one as the bar is one piece of metal so don't see how it could break and spin unless the mountings on the headlight are broken somehow?
PostPosted: Mon Dec 17, 2018 7:19 pm    Post subject: Reply with quote
Its A .
The tool is a socket so it will fit over a Hex .. you have a circle there im afraid .. there is nothing left to fit the tool over that it will grip to.
However and something ive not noticed before is that there seems to be an allen key fixing in the center of it ..
If it was me i would try a few different allen keys to see if i could release it that way.
At the end of the day though you will need a new base plate .
Trust me .. this is better than B ... as that way you would need a new headlight .
Indy Mechanic .
Paynewright
PostPosted: Mon Dec 17, 2018 7:37 pm    Post subject: Reply with quote
What about trying an imperial or BA socket or even a 4.5?
Ian
Paynewright
PostPosted: Mon Dec 17, 2018 7:40 pm    Post subject: Reply with quote
And perhaps get away with one of these:-
https://www.design911.co.uk/mobile/#part;id=135900
knw911
PostPosted: Tue Dec 18, 2018 7:53 pm    Post subject: Reply with quote
oh Damn Damn Damn Damn Damn
Well - some questions then folks.
1) If the hex bar has been rounded off, what can I do to get the light out.
2) and once I do get it out, am I right in thinking I can simply replace the hex bar rather than the whole tray?
Thanks guys. For what its worth, I have polished the other light in situ.. and it looks great. Such a difference for little effort. Still want to get them off the car so I can coat them with a UV spray.
PostPosted: Tue Dec 18, 2018 8:19 pm    Post subject: Reply with quote
First of all .. try some allen keys .. im thinking more the bar type .. they have a longer shank .. thats what i would be doing anyways .
Your not going to get any point nosed pliers in that hole i feel so the next step is arch liner and wheel off to get access to the base of the headlight .. i think mole grips on the bar might then work .
From my research looking for pictures .. and experience then im pretty sure you cant change just the rod .. you would need to remove the entire plate reguardless to do this .
I seem to remember the plate is around the £110 mark .. again looking for pictures .. off hand ive never replaced one but i expect the instructions are in the manual .. download in the 996 faq section .
Indy Mechanic .
knw911
PostPosted: Tue Dec 18, 2018 8:24 pm    Post subject: Reply with quote
I'm sure this is down to my stupidity .. but how would I use an allen key? The bar is solid. Where would the allen key go?
