997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
Cameltoe & Heel
PostPosted: Mon Dec 03, 2018 8:35 am    Post subject: Installing front wings Reply with quote
Guys when the wings were taken off the car for paint etc the factory seems to use some sort of sealant as well as the bolts, does anyone know what this sealant is and perhaps how it's applied?.
Trevor
Endoman
PostPosted: Mon Dec 03, 2018 9:47 am    Post subject: Reply with quote
Only reference I can find is this:- https://www.porscheshop.co.uk/911-wing-to-body-sealing-strip-blue-cover-65-98.html
When My 944 had a new wing it needed a bit of heat to soften the old sealant.
They probably use Sikaflex or similar nowadays. I'll call in to my local body place and ask him. He used to have a 968 and is quite clued up.
Cameltoe & Heel
PostPosted: Tue Dec 04, 2018 9:39 am    Post subject: Reply with quote
Thanks John, I had a word with my body guy and he seems to think a bead of clear silicone would work also, so may go down that route.
Trev
Cameltoe & Heel
PostPosted: Wed Dec 05, 2018 8:21 am    Post subject: Reply with quote
As I didn't remove the wings it took me a while to understand the orientation of the plastic clips that sit on top of the blind rivvet affair, there's a quite a number of these, talk about over engineering Smile
Trev
Gazc2
PostPosted: Wed Dec 05, 2018 8:57 am    Post subject: Reply with quote
I`m pretty sure there is a Porsche part number for the sealer think its like a roll of grey mastic sealer, I wouldn't use Sikaflex if you ever need to remove the wings in the future that would be murder to remove.
I don't have the 993 PET to hand however the 964 one shows
000 043 129 00 sealing strap 25 x 2mm
2007 997 Turbo & 924s in progress
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
Cameltoe & Heel
PostPosted: Wed Dec 05, 2018 3:54 pm    Post subject: Reply with quote
GazC2 thanks for that, just checked the 993 PET and it's in there so I've ordered a roll.
Trev
kas750
Reims
2006 Porsche 911
PostPosted: Wed Dec 05, 2018 4:38 pm    Post subject: Reply with quote
Just for anyone else thinking of doing this you can also bed the wings on brushable seam sealer which you can probably get from Halfords or any body factor.
AndyS
PostPosted: Wed Dec 05, 2018 8:59 pm    Post subject: Reply with quote
I'm sure I read somewhere that you shouldn't use Silicone Sealant on painted surfaces - something to do with the acidity... Question
Sikaflex is fantastic stuff - you could put a car together with the stuff, but as others have said, you'd never get it apart again.
When 9M put mine back together after the work I know they used the correct stuff from Porsche, so when I'm back home in a few weeks I'll fish out the bill to see what it was (and how much is cost me nooo )
Andy
1996 Polar Silver 993 Coupe - AKA 'the money pit'
A Class AMG & Golf TDi for the daily
Endoman
PostPosted: Wed Dec 05, 2018 11:56 pm    Post subject: Reply with quote
Good article here on sealants :- https://www.mig-welding.co.uk/seam-sealing.htm
Confirming that silicone is not a good idea.
9m used a polyurethane sealant on my RS sills as the tangs tend to break off quite easily.
Cameltoe & Heel
PostPosted: Thu Dec 06, 2018 8:25 am    Post subject: Reply with quote
Fantastic chaps, thanks all for your input, so have the tape and a tube of poly, maybe do the underneath with some seam sealer too, cover all bases Smile
I'll avoid the silicone approach, there's plenty of fresh paint between the mating surfaces.
John the mig welding site is great, I just aquired a decent 180 amp Mig from my old man, not had a chance to use it properly yet but looking forward to it when the time comes.
Onwards we march, wings to be remounted at weekend.
Trev
Wh1t3Kn1ght
2001 Porsche 996 Carrera 2
PostPosted: Fri Dec 07, 2018 10:41 pm    Post subject: Reply with quote
I'm just putting the wings back on my 944 turbo but according to PET2 the 944 is slightly different as it doesn't use anything on the contact surfaces. But just some of the sealant from a caulking gun against the joints. I bought a tube of Wurth Bond and Seal which appears to be the right stuff for the job and you can get it in black, grey or white. It is for seam sealing on boats and cars according to the wurth website.
All other models as far as I'm aware use the blue butyl strip between the contact surfaces as well as the seam sealer.
NOTE: Don't apply the seam sealer until the wing is fitted and you are happy with the position as it is apparently a real ***** to remove. You apply it just to the contact area joins to prevent moisture getting into the gaps.
Current Cars
2000 Violet 911 Carrera 2 3.4
1990 Panther Black 944 Turbo
2013 Mercedes A-Class A220 CDI
Previous Cars
1987 Alpine White 944S
1987 Black 944
