997 : 2004- 73
Boxster : 1997- 18
Cayman : 2005- 20
PostPosted: Sun Oct 28, 2018 11:25 am    Post subject: Reply with quote
rob001 wrote:
Phil 997 wrote:
Jamie_c wrote:
rob001 wrote:
Richtw wrote:
MaxA wrote:
This is an awful thread. I now feel the need for a set of those Rennline pedals. Or even a set of the adjustable Rennline pedals...
I was just about to say exactly the same thing....... Surprised
Those are indeed very good. On the throttle there is an extension at top and bottom. You can keep both or only one up to your preference. I keep both on as I'm used to rolling feed (top) and heel / toe (bottom) pending on how aggressive I must break.
Is there a UK supplier for the Rennline pedals or do you have to ship them from the US?
Design 911 do rennline stuff , but note rennline are for LHD cars so everything but the dead pedal should be ok, not sure how rob overcame the dead pedal unless he just made a LHD one fit a RHD car
https://www.design911.co.uk/fu/prod128178/Rennline-4PC-Pedal-Set-Rubber-Grip-Porsche-911---912---914---930---964---993/#
That's easy, I'm Dutch Very Happy
Floor Floor Floor Grin you know I kept looking at your pic and thinking bloody sure thats a left hand drive set up maybe he used a stock photo Thumb but now I get it Thumb
Richtw
PostPosted: Sun Oct 28, 2018 8:33 pm    Post subject: Reply with quote
New boots!! Super light and responsive! Very impressed with them Smile
2017 991.2 GTS
2010 997.2 C4S
 Filesize:  503.66 KB
 Viewed:  1925 Time(s)
FRZ 911
2007 Porsche 997 Carrera 4S
PostPosted: Sun Oct 28, 2018 10:03 pm    Post subject: Reply with quote
Very nice. thumbsup
997.1 C4S Meteor Grey Manual
MaxA
PostPosted: Mon Oct 29, 2018 7:53 am    Post subject: Reply with quote
My 997 had a major service including spark plugs. No issues to speak of.
I've done 9441km and two track days this past year (a bit less than earlier years, when it was my only car). I've also done maybe 7000km and three track days in the other car.
Since it's now below zero, I need to get my winters fitted. It was a bit crap coming down from the independent on summers in sleet/snow and 0c. The car was getting pretty wriggley.
2010 9972 C4S PDK: Carrara White, Sea Blue. Mostly driven, lightly modified, occasionally tracked, and usually a bit grubby.
FRZ 911
PostPosted: Sat Nov 03, 2018 3:16 pm    Post subject: Reply with quote
Forgot I had purchased this pedal set as it was so long ago! Embarassed Anyway, it was a bit miserable weather wise so decided to take the opportunity to fit them today.
Next up will be tackling the connection of an interior exhaust switch for my Top Gear system. With DucatiRob’s help with the relay and instructions I’m hopeful I’ll get it working.........despite being the worse DIYer I know!! Very Happy
 Filesize:  708.94 KB
 Viewed:  1716 Time(s)
 Filesize:  687.92 KB
-- 997 --
PostPosted: Thu Nov 08, 2018 8:19 pm    Post subject: Reply with quote
Well i got my gear knob, hand brake and exhaust tips highly polished like mirrors and does look nice i have to admit, just needs fitting back now!!
Oh also i self retrimmed the bits in Alcantara Thumb
J
 Filesize:  1.23 MB
 Viewed:  1599 Time(s)
 Filesize:  1.28 MB
v6matt
PostPosted: Sat Nov 10, 2018 12:48 pm    Post subject: Reply with quote
A bluetooth module
Stainless steel bolts/nuts for the Exhaust
A new water pump
A new thermostat (LTT)
Spark Plugs and Coil packs
A couple of new keyrings
A new drive belt
Some of the bits below !
2008 Carrera 4 - Gen 1 997
 Filesize:  186.45 KB
 Viewed:  1518 Time(s)
 Filesize:  195.08 KB
 Filesize:  197.1 KB
keendean
PostPosted: Sat Nov 10, 2018 6:57 pm    Post subject: Reply with quote
v6matt wrote:
A bluetooth module
A new water pump
A new drive belt
Good work- Which BT module did you go? Was it easy to fit? Any specific tools required? Any downsides?
v6matt
PostPosted: Sun Nov 11, 2018 2:54 pm    Post subject: Reply with quote
keendean wrote:
v6matt wrote:
A bluetooth module
A new water pump
A new drive belt
It is a MR12VOLT/LA POWER system, i.e the £118 one on Ebay/Amazon.
Seems to be a reverse engineered Dension.
You need the 7mm spanner, 5mm allen key and torx to remove the PCM but otherwise...not really!
It is definitely fiddly, as you need to find a suitable power/ground connection. Do a google search for "rennlist LA POWER", you will find a massive thread there with lots of info.
Hizza
PostPosted: Mon Nov 12, 2018 6:08 pm    Post subject: Reply with quote
I'm going to do a reply to this thread at the end of December entitled What did you buy your 997 this year. It has been an expensive year and there are still six weeks to go! However, today's big treat is a gundo hack by Paul at PCW Exhaust Mods. For a very reasonable sum the car now sounds like it should and very similar to my neighbour's Gen2 with PSE. Why would anyone want a Tesla when a car sounds this good? If anyone is thinking of having this done and is in the MK/Northampton area let me know and you can see and hear what you're missing! Rusty bolts all replaced too! Mechanic Very Happy
jl-c
PostPosted: Tue Nov 13, 2018 11:52 am    Post subject: Reply with quote
A New engine! Well near as, a fully rebuilt Hartech engine, pistons, wet liners, IMS bearing, chains guides, flywheel, clutch,dual pump, hoses, etc etc. Got to run it in now! but fingers crossed it'll see me out Very Happy
FZP
Paul Ricard
PostPosted: Tue Nov 13, 2018 10:43 pm    Post subject: Reply with quote
A new windscreen thanks to a conker falling from a tree.
An MOT
Bonnet resprayed under warranty.
PostPosted: Tue Nov 13, 2018 11:11 pm    Post subject: Reply with quote
Conker Dont know
Floor
MattyR
PostPosted: Wed Nov 14, 2018 10:59 am    Post subject: Reply with quote
HSC911 wrote:
Conker Dont know
Floor
Hahahaha! How big was the conker?!!
Atlas Grau on Ocean Blue Gen 2 997 C2 Carrera
Sold: Aventura Grün 993 C2 Carrera
SJD
PostPosted: Thu Nov 15, 2018 3:15 pm    Post subject: Reply with quote
Not normally one for stickers but I’ve added these subtle 70 years anniversary ones to the rear quarter windows.
 Filesize:  1.05 MB
 Viewed:  1069 Time(s)
 Filesize:  1.04 MB
FZP
Paul Ricard
PostPosted: Thu Nov 15, 2018 3:56 pm    Post subject: Reply with quote
MattyR wrote:
HSC911 wrote:
Conker Dont know
Floor
It was normal sized I guess, but it fell from a great height. I turned into Samuel L Jackson the next morning as I hear the windscreen crack as I drive out of the garage.
MattyR
PostPosted: Fri Nov 16, 2018 7:18 am    Post subject: Reply with quote
FZP wrote:
MattyR wrote:
HSC911 wrote:
Conker Dont know
Floor
Must have been a particularly dense conker Sad
First class film Thumb
FZP
Paul Ricard
PostPosted: Fri Nov 16, 2018 10:24 am    Post subject: Reply with quote
MattyR wrote:
FZP wrote:
MattyR wrote:
HSC911 wrote:
Conker Dont know
Floor
Look at the weight of a tiny stone that does the same thing. Just need a few things to happen in a certain way for it to crack a screen. Perhaps another half rotation of the same stone would result in no crack. Luck of the draw unfortunately.
New screen in now, so should probably get a new set of wipers to really give it that new car feel.
DucatiRob
PostPosted: Fri Nov 16, 2018 9:20 pm    Post subject: Reply with quote
Quite like those Thumb where from?
Mercedes CLK DD
Ducati 996
SJD
PostPosted: Fri Nov 16, 2018 11:06 pm    Post subject: Reply with quote
French company called “Classic Stickers”. Paid €14.
Goto page Previous  1, 2, 3 ... 127, 128, 129 ... 131, 132, 133  Next
Page 128 of 133
