996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
Richtw
PostPosted: Sat Oct 27, 2018 5:34 pm    Post subject: Exhaust heat shield over catalytic converter? Reply with quote
crawling around under my car I have found a loose heat shield over the catalytic converter. It would seem that there is a bracket actually on the cat that the heat shield is bolted too? It would appear to be rusted to nothing? Does this sound right or am I not looking at it properly?
If the bracket is on the cat is it a new cat/ weld a new bracket on to the existing cat?? Someone must have come across this already?
2010 997.2 C4S
PostPosted: Sat Oct 27, 2018 5:49 pm    Post subject: Reply with quote
Yup .. many times ..
The bracket rusts through and causes it to rattle but its on the engine side it normally rots through cat side from memory and its just a cover .. downside is to replace it you have to remove the lambda sensor ..
or .. cough .. cut it off .. cough .. sorry i have a cold and ramble due to the fever !
2 different parts depending on which side but this is a link for one of them ..
https://www.scuderiacarparts.com/part/142277/porsche/99711320930/heat-protection-catalytic-converter.html
 Filesize:  12.9 KB
 Viewed:  516 Time(s)
Richtw
PostPosted: Sat Oct 27, 2018 5:56 pm    Post subject: Reply with quote
Thanks Iain - best course of action lemsip and whiskey. For the heat shield just cut it off and ignore it or replace?? Wink
Thanks.
2010 997.2 C4S
PostPosted: Sat Oct 27, 2018 5:59 pm    Post subject: Reply with quote
I edited my post which you might not have seen ..
Official answer .. replace it of course ..
Un official answer .. well ive seen cars with them missing the same as ive seen gen 1 cars with the heat shield on them missing .. not seen one with a problem due to that so far .
Richtw
PostPosted: Sat Oct 27, 2018 6:02 pm    Post subject: Reply with quote
Thank you sir as ever. Hope you feel a bit better in the morning!!
2010 997.2 C4S
