997 : 2004- 77
Boxster : 1997- 18
Cayman : 2005- 18
NLW73
PostPosted: Fri Oct 26, 2018 7:41 pm    Post subject: near side rear rubber mud guard? Part ID Reply with quote
hi folks
previous owner has probably caught a high kerb or sth as its managed to damaged the side sill by the under sill and then pull this part back.
anyone know what it is and maybe the part number? the OPC has not been helpful.
pics added and are highlighted. thanks
997 C2s Schwarz
 Filesize:  135.72 KB
 Viewed:  683 Time(s)
 Filesize:  113.72 KB
 Viewed:  683 Time(s)
 Filesize:  120.42 KB
 Viewed:  685 Time(s)
 Filesize:  121.62 KB
 Viewed:  685 Time(s)
PostPosted: Fri Oct 26, 2018 7:54 pm    Post subject: Reply with quote
No 6 here should have that rubber " mud guard " attatched to it .. this panel often gets damaged so just the rubber bit wont fit if you get it on its own .. which i dont think you can.
Basically its a n/s/r mudflap quarter panel .. opc might be able to figure it out from that description .
I still struggle to belive opc parts dept cant actually find the parts when requested .. its their job after all .. sigh .
https://www.deroure.com/diagrams.asp?TBL=2859&MAK=3&MDL=26&SMA=0&SMO=0&ST=&SC=0
https://www.google.com/search?q=9975043940101C&client=firefox-b&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi8v9zv8aTeAhXFPOwKHfIZA9MQ_AUIECgD&biw=1920&bih=1045
-- 997 --
PostPosted: Fri Oct 26, 2018 8:04 pm    Post subject: Reply with quote
I changed both sides of mine a few months back, cos the clips were rusty and looked tired!! Was also gonna colour code them but decided not to!!, also alot of mud and crap gets jammed in there, good tip, get new screws and apply vaseline or silicone grease on the clips to stop corrosion!!
J
NLW73
PostPosted: Fri Oct 26, 2018 8:20 pm    Post subject: Reply with quote
you legends thanks fella. yeah the clip has been damaged and it won't lock back into the gap and yeah there is a load of crap has got in there so needs to be changed.
so if the problem child is on the near side/passenger is that classed as LH or RH?
997 C2s Schwarz
Mezgerite
PostPosted: Fri Oct 26, 2018 8:32 pm    Post subject: Reply with quote
deMort is a legend Mr. Green
BHZ661
PostPosted: Sat Oct 27, 2018 7:32 am    Post subject: Reply with quote
Thats classed as LH or nearside
