997 : 2004- 73
996 : 1997-2005 29
Boxster : 1997- 18
Cayman : 2005- 20
dmacp
2000 Porsche 996 Turbo
PostPosted: Fri Sep 28, 2018 1:14 pm    Post subject: Reply with quote
Maldern,
Thanks for your comments, Kits are available such as this one,
http://www.9products.com/product/4040/brake-caliper-spacer-front
which allow you to fit 350mm diamater rotors with the existing callipers and pads. There is a theoretical increase in available braking force due to the increased leverage.
What I'd like to know is, is it worth it?
I'm changing discs now anyway and it isn't much more for the 350mm dia over the 330mm, and the spacers are easy to fabricate.
asterix_the_gaul
1999 Porsche 996 Carrera 2
PostPosted: Sat Sep 29, 2018 6:25 am    Post subject: Reply with quote
Will you not get an unswept area of the disc face at the centre or are the 350 discs designed for the 996 pad area? If the same depth pads are used on the 997 350 discs as the 996 330 discs then it should be fine. Or maybe you are supposed to use a different pad?Yes you would notice the difference going to the bigger disc and seems a cheap and easy upgrade: I would check with the manufacturer of the spacers about any unswept area/pad size choice. Unswept areas not the end of the world but would annoy some people
uk996
PostPosted: Wed Oct 17, 2018 10:25 pm    Post subject: Reply with quote
Thread resurrection !
Anyone get any further with creating a reliable and repeatable process (at a decent cost) for using Cayenne/Audi calipers for our 996/996tt?
2002 996tt Aero in seal grey 6MT
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Wed Oct 17, 2018 10:33 pm    Post subject: Reply with quote
I have Smile
You can see them here.
http://911uk.com/viewtopic.php?t=125503&postdays=0&postorder=asc&start=220
Also done spacers for the rear to use 350mm rear disks with 996 turbo rear calipers and the required pipe to run the 27mm master cylinder. I will do a seperate thread on it with the required sums to show how the balance is affected at some point.
Plenty of details on that thread but it is a but spread out with other stuff.
This is for a 996, not turbo,C4S or GT3/2. I would just run the front 6 piston 996.2 GT3 calipers on those. As I do on my 996 turbo.
uk996
PostPosted: Wed Oct 17, 2018 11:57 pm    Post subject: Reply with quote
Where's the best place to buy them from?
OPC?
design 911 are selling them for £767 each. They've got a 10% promo on at the moment which is handy. Some of the older posts I've come across seem to indicate they were originally sold for £600 the PAIR by the OPC. Seems they've upped the markup :-(
MisterCorn
PostPosted: Wed Oct 17, 2018 11:59 pm    Post subject: Reply with quote
OPC?
Best place to buy what?
uk996
PostPosted: Thu Oct 18, 2018 12:24 am    Post subject: Reply with quote
GT3 6 pot calipers
MisterCorn
PostPosted: Thu Oct 18, 2018 7:30 am    Post subject: Reply with quote
uk996 wrote:
GT3 6 pot calipers
I would go with OPC. I have heard that prices have increased massively over the last few years though so brace yourself. With decent fluid / disks / pads and cooling ducts you have to be going pretty mad to run out of brakes. My standard brakes on the turbo were able to do 13 back-to-back emergency stops from 70mph with no increase in braking distance. When I changed to 6 piston calipers I got slight fade on the front brakes in the last couple of stops from the pads getting hot and not being as good as the pads I had on the original 4 pots. Line pressure was just as high so fluid was fine, but the rear brakes were doing more of the work from looking at relative wheel speeds and variations in line pressure from the operation of the ABS. The 6 piston ones do look the business though Smile
uk996
PostPosted: Thu Oct 18, 2018 7:56 am    Post subject: Reply with quote
Perhaps I’m going about this the wrong way. I haven’t had my 996t long. The brakes OE brakes appear to be in good condition. What I’m looking for is more initial response from the brakes, to me they feel wooden and unresponsive. However they do seem to wake up once warmed up and is ok at faster speeds.
The car had been driven by 9e and another independent Porsche tech, they both said it’s normal.
To me it really doesn’t inspire confidence. With my other cars, changing the callipers and the mc if necessary always resulted in better brakes that gave better feedback and modulation, I could feel that I could consistently slow down at the rate I wanted with confidence, with the 996, I haven’t.
I’m not actually too bothered whether the brakes are 4 or 6 pot. I want them to feel more responsive. What do you think?
On a related subject, I seem to remember someone saying the 911 would benefit from improving the rear brakes more, as there is significantly more weight concentrated at the rear.
maldren
PostPosted: Thu Oct 18, 2018 11:50 am    Post subject: Reply with quote
996 brakes need more pedal effort than typical modern road cars, once you get used to this they are fine.
Nobody has mentioned it but another option might be to change the feel would be to increase the servo assistance. Anyone tried it?
Mike
Stotty
PostPosted: Thu Oct 18, 2018 12:17 pm    Post subject: Reply with quote
I think I read somewhere that the 997 MC is a good upgrade for brake feel on 996’s.
2000 996, C2, manual, arctic/metropole, Koni shocks, H&R -30 springs, H&R ARB's, Rennline SS engine mounts, cup wheel, 170k miles. 2018 Touareg RLine Plus
MisterCorn
PostPosted: Thu Oct 18, 2018 12:21 pm    Post subject: Reply with quote
Yes, it is mentioned in a few places.
http://911uk.com/viewtopic.php?t=129789&highlight=
Stuart Mackay
PostPosted: Fri Oct 26, 2018 8:00 pm    Post subject: Reply with quote
Can confirm that Martin's GT3 m/c mode is a great thing and have fitted one to the C4 today, pedal now feels nice and progressive and not as though you are stamping on a block of concrete! thumbsup
2007 Speed Yellow 997 Carrera GT3 CS
2002 Guards Red Aerokit 996.2 C4S Cabriolet
2000 Westfield Cosworth
Goto page Previous  1, 2, 3
Page 3 of 3
