997 : 2004- 74
996 : 1997-2005 34
Boxster : 1997- 18
Cayman : 2005- 14
NIBrown
PostPosted: Wed Oct 17, 2018 9:56 am    Post subject: Chassis Rails & Bumper Supports Reply with quote
Well, I decided that it was well overdue for checking the condition of the chassis rails and replacement of the bumper supports that I knew were rotten.
Unfortunately I am putting the car up for sale soon as I need the money for a building project, and I wanted to be sure that the new owner had piece of mind on this issue.
More photos to follow on next post, seems there may be a limit on the number per post?
Photos may be in reverse order also!!
993S with 62K now sold :-(
MK7 Golf R, SLK 300,
Skoda Yeti 140TDi 4x4 with 152K Smile
Previous
Mk5 Gti Pirelli Edition, Audi TT diesel, Defender 300Tdi CSW,90 Tomb Raider, Golf 7R, 993S
Mk6 Golf GTD, Mk5/4/3 Golf Gti, Audi S3
Rust hole replaced with some nice new steel welded in
 Filesize:  147.48 KB
 Viewed:  2493 Time(s)
Off side chassis rail after cleaning down and cutting out a small area of rust....could have been worse, just got it in time!
 Filesize:  246.71 KB
Surface rust to brackets that cleaned up quite easily
 Filesize:  293.8 KB
Off side bracket
 Filesize:  321.68 KB
Off side chassis rail after removing bracket
 Filesize:  277.59 KB
Near side chassis rail cleaned up, phew, no significant rust:-)
 Filesize:  339.14 KB
Inside of near side cavity, looks pretty clean
 Filesize:  285.49 KB
Near side bracket removed and the rust exposed
 Filesize:  334.42 KB
My essential parts from Porsche Cardiff, together with the all important 90% zinc primer and protection wax. Seems that these products are the best available and what everyone else seems to be using.
 Filesize:  357.78 KB
First rusty item to replace
 Filesize:  264.32 KB
View user's profile Send private message Send e-mail Yahoo Messenger
NIBrown
PostPosted: Wed Oct 17, 2018 10:04 am    Post subject: MORE PHOTOS Reply with quote
More of the progress
Previous
Near side chassis rail covered in protection wax prior to re-assembly
 Filesize:  94.31 KB
 Viewed:  2476 Time(s)
Plate covered in protection wax prior to re-assembly
 Filesize:  123.27 KB
 Filesize:  168.52 KB
Off side plate cleaned, primed and painted
 Filesize:  148.58 KB
Near side plate, cleaned primed and painted
 Filesize:  170.72 KB
Off side rear of chassis leg primed and painted after removing a very small amount of surface rust
 Filesize:  177.01 KB
Near side rear of chassis leg primed and painted after removing a very small amount of surface rust
 Filesize:  169.45 KB
Off side chassis leg primed and painted
 Filesize:  171.05 KB
Near side chassis leg primed and painted
 Filesize:  216.78 KB
Inside off side chassis rail, again looks pretty clean
 Filesize:  116.28 KB
NIBrown
PostPosted: Wed Oct 17, 2018 10:09 am    Post subject: Final photos Reply with quote
The last of the assembly photos, just the bumper, reflector etc to reinstall and I'm there Smile
After plates and supports were re-fitted, I gave everything another good blasting of wax for protection....shouldn't need to get back in there for a very long time!
Previous
Off side bumper supports fitted, also coated with protection wax
 Filesize:  173.32 KB
 Viewed:  2465 Time(s)
Near side bumper supports fitted, also coated with protection wax
 Filesize:  170.5 KB
Off side chassis cavity blasted with a good helping of wax
 Filesize:  183.64 KB
Near side chassis cavity blasted with a good helping of wax
 Filesize:  150.07 KB
Off side chassis rail covered in protection wax prior to re-assembly
 Filesize:  102.59 KB
wilsonny
PostPosted: Wed Oct 17, 2018 11:55 am    Post subject: Reply with quote
looking good. just be ready for all the smoke after first start up when that wax hits the hot exhaust ! I had people running from the petrol station as smoke rose from the car the first time after I did mine.
1996 C2 manual
Gazc2
PostPosted: Wed Oct 17, 2018 12:35 pm    Post subject: Reply with quote
Good job, they didnt look too bad compared to some looked pretty much surface rust Thumb
2007 997 Turbo & 924s in progress
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
NIBrown
PostPosted: Wed Oct 17, 2018 1:05 pm    Post subject: Reply with quote
I was quite pleased with the condition of the chassis, seen some far worse too, but then again, the car has only done 64K!
And to think, this rust must have started to form in the first 14 years, I have never driven it out on a rainy day, let alone on salty roads!!
Thank you for warning me about the smoke, hope it doesn't take too long to burn off Laughing
Previous
badlands
PostPosted: Wed Oct 17, 2018 1:43 pm    Post subject: Reply with quote
Nice work. They didn't look bad at all, but you never know till you look! Need to get this job done on mine at some point too.
current: 993 carrera coupe, manual, iris blue, bilstein pss10
ex 964 c4
ex 993 carrera cab
NIBrown
PostPosted: Wed Oct 17, 2018 2:03 pm    Post subject: Reply with quote
I put it off for a long time, as I have seen what a can of worms you can open!
The taking apart is pretty time consuming, as there are many nuts and screws that have to be cut/ground off due to being rusted on!
I found that a dremel with a metal cutting bit that looks a bit like a drill bit was a life saver, it allowed me to cut various seized nuts off without snapping the welded in studs Thumb
I sprayed penetrating oil on all the nuts etc a few days before I started, it helped to get a few of them off.
Now is the time to get stuck in, whilst in winter hibernation....good luck Thumb
Previous
decgraham
PostPosted: Wed Oct 17, 2018 4:13 pm    Post subject: Reply with quote
Hi NIBrown,
Good work Thumb
While you've got all the rear end off you might want to check cam chain cover gaskets, cam chain tensioner gaskets, oil bridges as well as top and bottom cam shaft cover gaskets. I didn't and then had to go back in again.
ATB Smile
Jet Jock
PostPosted: Wed Oct 17, 2018 7:27 pm    Post subject: Reply with quote
Nice one NIBrown. I tackled this particular issue 2 years ago. I was able to salvage most of the chassis rails etc and went about aqua blasting them and rust proofed before installing again. Goodwork!
Baz
993 C2, RSR's, Cargraphic 100 Cell Cat, Turbo Twist Hollows, Brembo Big Reds Turbo Brakes, Big Ovals, Wayne Schofield Remap, KW Supersport set up by Chris Franklin, RS engine and transmission mounts, Fabspeed induction kit, FD Motorsport SSK and Golden Rod, MPL Clutch Slave Cylinder, HID conversion...
instagram.com/bazzer_a
911UK
Porsche Community
Porsche Community
1997 Porsche 993 Carrera 2
PostPosted: Wed Oct 17, 2018 7:33 pm    Post subject: Reply with quote
nicely done NIBrown Thumb Thumb Thumb
FOLLOW 911UK ON TWITTER
mashby
PostPosted: Wed Oct 17, 2018 8:29 pm    Post subject: Reply with quote
Excellent work. You were very lucky.
I'm in the process of doing mine as we speak. Unfortunately they are in a much worse state but the car has done nearly 160k. The wing support brackets were unsalvageable so I have new ones ready to fit and I've had a repair panel made for the near side chassis leg. The off side only needed a 2" square cutting out.
Apart from this rot everything else looked in good shape under there
thumbsup
1994 993 C2
1974 MGB GTV8 3.5
1980 MGB Roadster 1800 stage 3
NIBrown
PostPosted: Thu Oct 18, 2018 7:37 am    Post subject: Reply with quote
Baz
Cheers Baz,
I think that every 993 should be looked at irrespective of mileage, I would bet that there is the start of rot in even the lowest mile cars.
A very rewarding job done Thumb
Previous
NIBrown
PostPosted: Thu Oct 18, 2018 7:40 am    Post subject: Reply with quote
thumbsup
Hi Mashby, sounds like I got away very lightly, good luck with yours, it'll be like new once repaired Thumb
Don't forget to post your work Smile
Previous
NIBrown
PostPosted: Thu Oct 18, 2018 7:43 am    Post subject: Reply with quote
decgraham wrote:
Hi NIBrown,
Good work Thumb
ATB Smile
Hi decgraham,
All looked pretty good down there, so I am hopeful that with the low mileage, they will last for a bit longer Thumb
Previous
Cameltoe & Heel
PostPosted: Thu Oct 18, 2018 7:46 am    Post subject: Reply with quote
This is great work NIBrown.
The chassis leg corrosion issue is a strange one, some suffer much more than others for sure, I'm not sure it's mileage related either.
It's an easy enough fix to do at home if confident enough, think it was Baz that first brought it to our attention.
Good thing with this job is you can sort all the rear end bumper attachment issues at the same time.
I'm currently replacing two rear brake lines that attach to the flexi hose, mine were corroded but boy do they take some shifting. Also replaced part of engine bay skirt/seal which was slightly split and the engine sound pad has been renewed.
How much did the new bumper brackets cost, the three that sit along the top?, was thinking of getting new myself or have them zinc coated.
Trev
NIBrown
PostPosted: Thu Oct 18, 2018 12:01 pm    Post subject: Reply with quote
Trev
Hi Trev,
You are right, the chassis corrosion issue doesn't really appear to relate significantly to the mileage, weird Question
Not an entirely difficult job to undertake yourself, agreed, but a bit of time and patience is required to remove the seized nuts and bolts frustrated
If you mean the brackets that are pop-riveted onto the plastic bumper, I only had to replace one, as the other were perfect, it was the middle one at £36.59 incl VAT after discount. They come anodised anyway, so no need to zinc plate.
The other bumper support brackets painted black, are 2 per side. Can't remember how much the rear ones were, as I bought these quite some time ago, but the front ones are £78.47 each. These are more likely to corrode over time - mine lasted over 20 years and 64K miles, so in reality, new ones should last longer as these cars are getting used less and less Dont know
I've been into mine replacing brake lines, as I renewed the hoses to all calipers for Goodridge braided and they were seized on, so had to cut the brake pipes! good excuse to bleed the whole system through and refill with some nice DOT 4!
Previous
ballcock
1996 Porsche 993 Carrera 2
PostPosted: Mon Oct 22, 2018 6:02 pm    Post subject: Reply with quote
......think it was Baz that first brought it to our attention.
Trev
I’m not letting that fecker Baz take the credit for this Grin
http://www.911uk.com/viewtopic.php?t=57816&postdays=0&postorder=asc&start=0
Ex. '99 996 C2 manual coupe.
madalaa
2009 Porsche Boxster 987
PostPosted: Tue Oct 23, 2018 8:23 am    Post subject: Reply with quote
Hi there Barney ....... long time no see ...... bye
Yup it was he indeed who put the cat amongst the pigeons ....... before that it was a happy life of "ignorance is bliss" ...... Floor
Cameltoe & Heel
PostPosted: Tue Oct 23, 2018 8:50 am    Post subject: Reply with quote
Trev
Sorry Ballers Smile, ha ha ha
