991 : 2011-2019 0
997 : 2004-2012 0
Boxster : 1997- 22
Oilline
PostPosted: Thu Oct 04, 2018 2:39 pm    Post subject: Door check strap, A post repair Reply with quote
My drivers side check strap has ripped itself out of the A post as they do.
The garage who have priced to do the job are advising that i have both sides done even though the passenger side is still ok.
Do i go ahead and get both side repaired and strengthened or leave the near side as is? I see the advantage of having it done then its done but part of me doesn't like the thought of the A post being chopped into when its ok.
PostPosted: Thu Oct 04, 2018 2:43 pm    Post subject: Reply with quote
Given the passenger door is likley to be opened/closed less than the drivers I'd leave it.
You can 'spot-weld' these check-straps if you don't want the body chopped. How visible it will be depends on the skill of the welder though
The game's afoot. It's time to put a bit of (Colini) stick about......
Oilline
PostPosted: Thu Oct 04, 2018 4:15 pm    Post subject: Reply with quote
The divers side had been crudely spot welded previousley and now need doing properly.
PostPosted: Thu Oct 04, 2018 4:21 pm    Post subject: Reply with quote
Cut and shut job then what
sday12
PostPosted: Thu Oct 04, 2018 7:25 pm    Post subject: Reply with quote
Who’s doing the work?
These really need to be strengthened to ensure it doesn’t happen again, so you’ll need a experienced fabribricator/Porsche specialist.
Spot welds fail and are a bodge.
1997 Schwartz Black Manual 993 Carrera 2S Hardbacks/Hollow Spokes + Tequipment goodies
sday12
PostPosted: Thu Oct 04, 2018 7:28 pm    Post subject: Reply with quote
double post
Endoman
PostPosted: Thu Oct 04, 2018 8:15 pm    Post subject: Reply with quote
Ninemeister did my driver's side about 5 yrs ago, you just can't see the join.
N/S is original 24 yrs old.
Cameltoe & Heel
PostPosted: Fri Oct 05, 2018 7:38 am    Post subject: Reply with quote
Both of mine were shot, now repaired pre-spay job, done properly but not easy or cheap to do right. But to me the clicking door ruins the experience.
Trev
cableguy
PostPosted: Fri Oct 05, 2018 8:03 am    Post subject: Reply with quote
No reason why any competent welder or bodyshop can do this at a reasonable price.
Typically most go with a Pork specialist and pay the obligatory Porsche Tax...
C.
Pork!
Cameltoe & Heel
PostPosted: Fri Oct 05, 2018 9:41 am    Post subject: Reply with quote
C.
yes absolutely correct but someone you trust, you want the right finish.
Trev
