997 : 2004- 63
996 : 1997-2005 29
Boxster : 1997- 26
RUDDY
PostPosted: Wed Sep 26, 2018 12:46 pm    Post subject: 3.6 C2 ownership thread Reply with quote
Quick question gents, the rear alloy beam that links the two alloy suspension members together , runs across the car under the gearbox/engine , can this simply be unbolted and removed ?
It doesn't look like it supports anything and simply braces across the car.
This item but on a 3.6 manual
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F223123371538
Cheers, Paul
PostPosted: Wed Sep 26, 2018 6:40 pm    Post subject: Reply with quote
Yes but you would only remove it if dropping an engine .. what are you up to ?
Bottom bolts .. 18 / 16 mm undo and remove .. top bolts slacken off then a bit of levering side to side will get it out ... slides downwards basically .. Oh brace bars removed of course .
Take note of the direction .. it has to go back the same way .
Indy Mechanic .
RUDDY
PostPosted: Wed Sep 26, 2018 8:59 pm    Post subject: Reply with quote
Thanks for the reply.
I've SORN'd the car for Winter, not everyone's choice I know but it's not a daily runner, I'm gonna do some cleaning underneath, have the alloy parts vapour blasted, suspension refresh, new brakes etc
I sold the car pictured in my link after doing all the work bar paint myself , then bought the 997 , I like stuff to be clean and it gives me something to do during the day, retired.
https://www.flickr.com/photos/159053845@N04/
JayG60
PostPosted: Wed Sep 26, 2018 9:13 pm    Post subject: Reply with quote
Great job on the 924!
Can I ask where did you get your parts vapour blasted?
Jay
MarkC4S
PostPosted: Thu Sep 27, 2018 6:45 am    Post subject: Reply with quote
WOW now that is clean worship
PostPosted: Thu Sep 27, 2018 6:11 pm    Post subject: Reply with quote
Ok Smile
One thing i forgot to point out which you may already know but better to be safe .... do it on axle stands and NEVER drop the car back on its wheels without the brace bar being fitted .
That would be bad .. very bad ...
Did i mention that would be bad ?
Indy Mechanic .
RUDDY
PostPosted: Thu Sep 27, 2018 10:13 pm    Post subject: Reply with quote
Thanks Demort, the car is up on stands and probably will be for the foreseeable , I'm guessing to drop the car with no rear beam in will see a bit of twisting, certainly no plans to do so anyway.
I'm also giving thought to taking the driveshafts off and removing all the cables etc then dropping the suspension units out as complete assemblies along with the alloy chassis side members, apart from requiring a full geo set up afterwards is there any hidden snags ?
Looks like 3 large bolts into the chassis via rubber mountings and 3 strut top nuts.
RUDDY
PostPosted: Thu Sep 27, 2018 10:18 pm    Post subject: Reply with quote
Jay
Hi Jay, just a small local firm that specialise in classic car work, dropped my first batch of parts there today.
Cheers, Paul
PostPosted: Fri Sep 28, 2018 4:35 pm    Post subject: Reply with quote
If you drop the suspension hangers each side that the brace bar bolts to then you will need a geometry check done when its all back together .
Indy Mechanic .
RUDDY
PostPosted: Wed Oct 10, 2018 2:01 pm    Post subject: Reply with quote
Work continues
 Filesize:  1.53 MB
 Viewed:  12310 Time(s)
RUDDY
PostPosted: Wed Oct 10, 2018 2:05 pm    Post subject: Reply with quote
And
 Filesize:  1.83 MB
 Viewed:  12300 Time(s)
 Filesize:  1.83 MB
RUDDY
PostPosted: Wed Oct 10, 2018 2:10 pm    Post subject: Reply with quote
Sorry, I am rubbish with modern technology...
PostPosted: Wed Oct 10, 2018 5:55 pm    Post subject: Reply with quote
Stuff me that is one clean car !!
Im not sure they were that clean when i used to do PDI,s on them Thumb
Indy Mechanic .
RUDDY
PostPosted: Sun Oct 14, 2018 7:22 am    Post subject: Reply with quote
Stripped caliper down and rebuilt, jury is still out on the Brembo branding
 Filesize:  1.49 MB
 Viewed:  12075 Time(s)
RUDDY
PostPosted: Sun Oct 14, 2018 7:26 am    Post subject: Reply with quote
Fitted
 Filesize:  1.65 MB
 Viewed:  12072 Time(s)
RUDDY
PostPosted: Sun Oct 14, 2018 7:33 am    Post subject: Reply with quote
I’ve started reassembling the o/s , new coffin arm and rear track control arm (same as n/s)
The anti roll bar has been powder coated and has new bushes and new clamps, not worth cleaning the old ones at under £3 each from Porsche
Caliper is built and ready, new disc, pads, sensors, HEL line
Waiting for new nuts/bolts coming from Porsche for final assembly
RUDDY
PostPosted: Sun Oct 14, 2018 7:43 am    Post subject: Reply with quote
And
 Filesize:  1.19 MB
 Viewed:  12058 Time(s)
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Sun Oct 14, 2018 8:02 am    Post subject: Reply with quote
That looks fantastic. Top job.
RUDDY
PostPosted: Mon Oct 15, 2018 9:27 am    Post subject: Reply with quote
A busy Sunday
 Filesize:  1.62 MB
 Viewed:  11941 Time(s)
RUDDY
PostPosted: Mon Oct 15, 2018 9:29 am    Post subject: Reply with quote
I’ve gone black for the tips
 Filesize:  1.92 MB
 Viewed:  11938 Time(s)
Goto page 1, 2, 3, 4, 5, 6  Next
Page 1 of 6
