997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
cossiemike
PostPosted: Sat Aug 18, 2018 3:47 pm    Post subject: Another dead engine Reply with quote
Hi,had my 2001 3.4 C2 for a couple years and thought it was ok.Mileage 91k Went for a quick run today.All ok and did about 20 miles.Stopped at workshop for 15 mins or so and left for a blast. 5 miles later while following a slow car about 50 noticed a slight rattle.Oil pressure had dropped slightly so stopped. Had my son tow me back with the Disco to my workshop. Started the engine briefly,definately bearings shot.Hopefully not to much damage caused. The race workshop I use for my other cars used to run a GT3 in Britcar so should be able to fix. Good excuse to get the Exige out again.Will let you know the results of the strip down. Mike
PostPosted: Sat Aug 18, 2018 3:53 pm    Post subject: Reply with quote
Could be a number of things and you won't know till you strip it. What do you mean by bearings shot?
cossiemike
PostPosted: Sat Aug 18, 2018 4:05 pm    Post subject: Reply with quote
The engine is rattling like a tin can.
PostPosted: Sat Aug 18, 2018 4:26 pm    Post subject: Reply with quote
Could be anything.
cossiemike
PostPosted: Sun Aug 19, 2018 2:32 pm    Post subject: Reply with quote
alex yates wrote:
Could be anything.
Agree but sounded like the bottom end.Hopefully will get the engine out next week.
NLW73
PostPosted: Sun Aug 19, 2018 3:24 pm    Post subject: Reply with quote
Could be a worn tappet? Did it do it on tick over then go when you revved the engine?
997 C2s Schwarz
cossiemike
PostPosted: Sun Aug 19, 2018 6:50 pm    Post subject: Reply with quote
Hi,no on start up it clattered so bad switched off immediately.Mike
GMG
PostPosted: Sun Aug 19, 2018 7:11 pm    Post subject: Reply with quote
Could well be the ims...mine sounded the same;managed to turn it off quickly enough to maintain the timing thereby avoiding total engine destruction!
I genuinely hope you discover something less expensive?
cossiemike
PostPosted: Mon Aug 20, 2018 8:08 pm    Post subject: Reply with quote
Hi spoke to Steve at the race workshop and he will drop the engine out in a couple weeks,doesn't think it will be a problem to do. Fingers crossed.
coullstar
PostPosted: Mon Aug 20, 2018 9:13 pm    Post subject: Reply with quote
Drop the oil, check the filter and take the sump off. It will give you a good indication of possible issues.
cossiemike
PostPosted: Wed Nov 28, 2018 4:53 pm    Post subject: Knackered 3.4 Reply with quote
My engine finally let go a few months ago. Have been to busy to do anything about it ,so finally dropped the engine out and dropped it off at Hartech.Result knackered crank etc. Quote from Grant for partial rebuild with s/h crank,rod.Plan B with new liners etc & top end overhall.Plan C full rebuild to 3.7. So 3.7 it will be after reading the article in 911 & Porsche world. Hopefully it will be done before the end of the year. Mike.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Wed Nov 28, 2018 5:01 pm    Post subject: Reply with quote
Sorry to hear that. Was it the main bearings which went in the end? Do you know what mileage the engine was on?
Osh
PostPosted: Wed Nov 28, 2018 5:14 pm    Post subject: Reply with quote
Mike - as MC says, sorry to hear this.
Please can i ask, if its OK with you - that you come back here and give us full and regular updates...??
Hope this all gets sorted for you m8 Thumb
Osh
PostPosted: Wed Nov 28, 2018 5:18 pm    Post subject: Reply with quote
As above. Sorry to hear. Watching with interest.
cossiemike
PostPosted: Wed Nov 28, 2018 5:20 pm    Post subject: Reply with quote
Hi,it was a big end that went and did the rod & crank.With it stripped the bottom end was on last legs through wear.Top end looked ok but it was showing wear.Will try to update with some pictures. Mike.
cossiemike
PostPosted: Wed Nov 28, 2018 5:32 pm    Post subject: engine internals Reply with quote
Some pictures of the internals.
 Filesize:  139.03 KB
 Viewed:  2755 Time(s)
 Filesize:  118.03 KB
 Filesize:  121.55 KB
 Filesize:  111.92 KB
cossiemike
PostPosted: Wed Nov 28, 2018 5:35 pm    Post subject: Reply with quote
Mileage about 90000 & was running sweetly until a bit off a thrash in 3 figures.a long curve and oil surge I think.
sackerley
PostPosted: Wed Nov 28, 2018 6:48 pm    Post subject: Reply with quote
Always sad to hear of failures like this but I’m Very interested to see how it works out with the 3.7 upgrade.
Best of luck with it. Please keep us posted Thumb
1998 Artic Silver 996.1 - manual - carbon interior - Momo Protopito
Daily LCI M2
Daily... air cooled... Vespa
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Wed Nov 28, 2018 7:11 pm    Post subject: Reply with quote
Ouch... but exciting to be doing a 3.7!
Will be interesting to follow the progress.
911munKy
PostPosted: Wed Nov 28, 2018 7:43 pm    Post subject: Reply with quote
Not really a high mileage then, shouldn’t have gone pop through wear and tear for many more miles. Abused when it was younger?
2000 C2 996
Goto page 1, 2, 3, 4  Next
Page 1 of 4
