997 : 2004- 76
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
pancobalt
PostPosted: Wed Feb 14, 2018 7:09 pm    Post subject: oil leak and heavy clutch- a pleasent end Reply with quote
I purchased my car 3 yrs ago with a heavy stiff clutch pedal but perfectly fine working clutch (allegidly they are all like that ).
For the last year, i have had an oil weep from the engine, suspected rear main oil seal . Finally after much debate , porsche extended warranty agreed to repair the oil leak. As the "misting" had turned into a full on drip.
Smile
So gearbox removed and i am permitted to assess the components neatly laid on the bench with a very friendly knowledgable patient master tech.
Rms seal dry as a bone. The culpret was the ims seal. And yes on my april 2005 car , i have the later revised ims bearing ( there is a huge nut at the end of the shaft ),
Flywheel sweet , no hotspots or blueing , 50% clutch plates remaining, we tried to look for date stamps on both parts but were unsuccessful .
Pitting found on clutch slave cylinder and clutch fork (release ), so these were both replaced for a reasonable £250 all in, while we were in there.
Well happy with the service from opc byfleet last week. My oil usage should in theory, be less, not major to start with ,and for some reason my clutch pedal feels lighter and not heavy at all.
Many things have fallen, only to rise higher.
2005 c2s blue.
Jam911
PostPosted: Wed Feb 14, 2018 8:36 pm    Post subject: Reply with quote
Byfleet are excellent
Current '07 997 C4S
Ex '99 2.5 Boxster
