Bridgestone N rated cracking after 3 years
997 Coast
4 Apr 2015
671
Fellow owners
Have anyone else noticed this ( mine pre mot inspection at revolution porsche)
Tyres manufactured 2015 / fitted July 2015 @ 36k miles - drawn to my attention this week at mot / major service time. 44k miles
Fronts 235/35/19 N rated
Rears 295/30/19 N rated
About 8,000 over three years
Since fitting had 2 wheel alignment checks so camber etc aint a issue - tread depth now fronts 6mm rear 4mm
Is it worth informing Bridgestone ( be fobbed off) or go to a french tyre that provides great grip
Comments
Michelin next time
Slightly off topic, but 8k in 3 years AND it is a daily driver??!! I have done 1,500 miles in mine already, and only had it 2 months and it is a 3rd car!!! How on earth do you manage to ration yourself that much???
I have seen it .. normally on fronts only .. not sure if its caused by low pressure running .. hard cornering or just a fault in a batch of tyres .. older tyres do crack and thats kinda normal but not at the age of yours .
I doubt the company will be that interested .. rear tyres are almost at 3mm which is when Porsche recomend replacement .
Cracking from my point of view is an advise on a service .. im only concerened if the cracks go down to the coords .. in that case its a little more than an advise !
You can raise it with Bridgestone, they may agree to investigate or provide some sort of gesture, but I think you'll just have to replace all four. Presumably with Michelins.
I take it you check the pressures regular.
I would imagine incorrect pressures could have an effect
I have Bridgestones and the rears are begining to crack at the outer edge between the tread blocks. I had considered sticking with the same but as it seems a more common problem, replacements will be Michelin.
:thumb: Totally agree - intend to replace with Michelin. Better grip I am informed. Thats a bonus.
Small cracks at the base of the tread blocks, whilst not exactly welcome, could be just the sign of a tough life.
Cracking in the sidewalls (depends where) if the use and inflation specs have been respected is worrisome as great efforts are made to ensure that tyres do not crack or otherwise degrade
Whilst not a garage queen it's been sensibly driven and not hammered.
Tyre pressures maintained at 34 / 40 religiously.
124,559
1,441,518
48,973
mkrt1972
