EGTE said:Props to Baz for encouraging someone to DIY!
infrasilver said:I think someone on here found a double row with the same spec available, I would go for this if possible. The larger bearing will require machine work and when I was last offered this it was around £600.
911munKy said:infrasilver said:I think someone on here found a double row with the same spec available, I would go for this if possible. The larger bearing will require machine work and when I was last offered this it was around £600.
£22
https://www.onlinebearings.co.uk/32...ular-Contact-Ball-Bearing-Polyamide-Cage.html
Well done MC, watching with interest
Demort said:Bigger pictures so that i can zoom in please
3 rd picture looks like grit on the sump pan ?
Nothing on the strainer though .
MisterCorn said:If there any particular technique to open the oil filter to inspect it? It is still fitted.
