997 : 2004- 62
Boxster : 1997- 24
Cayman : 2005- 20
blackram
PostPosted: Thu Aug 10, 2017 5:09 pm    Post subject: Will it fit? Reply with quote
Hi guys - great forum for a newbie such as me.
I am in the market for a 2011/2012 991 Carrera S and am just renovating my single garage ready for the car once found. A question.....my garage at the widest part internally is 2.8m. Bearing in mind that the car at its widest is 1.808m, will I be able to get in and out of the car? How wide do the doors have to open to enable you to get in? Anyone have one in a single garage of similar proportions please? I am 5'10'' and of average build and fairly flexible! Thanks for reading. John
PostPosted: Thu Aug 10, 2017 5:31 pm    Post subject: Reply with quote
Welcome to 911uk John.
That 1808mm is the width if the car excluding mirrors which on the 991 are mounted on the door itself.
Obviously there would be no problem getting the car into the garage but I fear you would have trouble getting the door open sufficiently to get in comfortably even if you parked the car really tight to the left.
The doors on a 991 are big - bigger than on my 997 - and I'd hate to put that in a 2.8m wide garage.
I hope you're a lot more flexible than me. Although that wouldn't be difficult. Old
Good Luck.
Waitaminute
PostPosted: Thu Aug 10, 2017 9:40 pm    Post subject: Reply with quote
Yes, it will fit comfortably.
My garage is 2.9m width and houses a 991.2 Carrera S easily with enough room for me to comfortably get out of the drivers side and also leave enough space to walk all around the perimeter of the car. I clean and detail the car inside the garage with no problems and, at a pinch, passenger can get out too.
If I gave up 10cm of width I would find it harder to walk all around the car but, by parking a little to the left, getting in and out would be no issue at all.
The door has three points as it opens where it notches into place and settles. My garage allows me to open the door to the second notch which allows me to get in and out without too much drama and I and mid-50's and overweight.
blackram
PostPosted: Thu Aug 10, 2017 9:47 pm    Post subject: Reply with quote
Thank you to you both. Sounds promising 'waitaminute' I too am mid-fifties and, if I listen to my wife's propaganda, probably a little overweight too!
What I may do is ask the local OPC (only 2 miles away) if they could drop over to my house in one and test the garage size. It will be serviced by them when I get it so in their interest to prove it will fit I guess! Unless there is anyone in the Bristol area fancies bringing their 991.1 over for a trial fit, a cuppa and a chat about what options I should look for when buying? Smile
Waitaminute
PostPosted: Thu Aug 10, 2017 10:22 pm    Post subject: Reply with quote
Just popped into the garage. Top photo shows the drivers door open to 2nd notch and the next photo shows the room left on the passenger side.
 Filesize:  924.78 KB
 Viewed:  7968 Time(s)
 Filesize:  1.05 MB
weejimmy
PostPosted: Fri Aug 11, 2017 8:29 am    Post subject: Reply with quote
A trick I did in the past when I had a single garage was to mount some carpet on the wall at the contact point where the vertical door edge meets the wall. That way you can open the door right out if you need to without worrying about the paint hitting the wall.
I have a similar arrangement in my current garage where I have a cupboard on the end wall that I drive 'under' (only by about 1 foot at most) which restricts access to the bonnet when it is opened. I bought some foam backed with adhesive off Amazon of about 1 foot square and stuck it to the bottom of the wall cupboard. When the bonnet opens the lip just lightly comes into contact with the foam. Used it for 3 years with my C4s without issue or any marks on the paint. The GTS dimensions are close enough that it is still in the right spot!
I also have a a wooden H shaped ladder frame on the floor. One of the long edges is against the end wall, I drive in until the front tyres hit the other long edge. Makes it impossible for me to ding the nose as the frame is about 1.5" tall so the front wheels cant push over them at slow speeds and you can readily feel when they come into contact.
Actually, calling it a 'frame' is a bit of an overstatement. It's a loose arrangement of wooden battens! Over the years it's been tweaked to accommodate various cars with differing gaps from the front edge of the front wheels to the bumper including an e46 Mc CSL, couple of e92 M3's, now 911's. I just replace the short battens to suit. I keep thinking I should screw the battens together, but TBH its easier to get my son to push them back into shape every once in a while before I drive in! Thumb
I know others do things like hang balls on string that hit the window etc, but my solution has an element of protection against your foot coming off the clutch or inadvertently stabbing the throttle!
Current: 2020 AM Vantage
Past: 2017 991.2 C4GTS
Past: 2014 991.1 C4S
blackram
PostPosted: Fri Aug 11, 2017 10:22 am    Post subject: Reply with quote
Waitaminute - that looks like plenty of room and you say that your garage width at the widest where the doors open is 2.9m? Mine is 2.8m so negligible difference (5cm for each side) so that will be no issue. Thanks for taking the trouble - very much appreciated. Lay in bed last night worrying that it wasn't going to fit!! "Darling, we may have to move house" is not an option!
Wejimmy - I will have to do a simlar thing due to lack of space. I also have a mezzanine floor above my garage which is accessed by a wooden modular staircase at the end of the garage. That is now going to be hinged and will swing up to the left hand wall out of the way. Weighs a ton so will have to be very secure to stop it swinging back when teh car is parked !! Thank you for the reply.
Waitaminute
PostPosted: Fri Aug 11, 2017 3:53 pm    Post subject: Reply with quote
Yes, mine is 2.9m at the widest point. The extra 10cm vs yours is no-doubt nice to have but I can't see it being a deal breaker at all as far as ingress / egress.
That said, the "Darling, we may have to move house" option is often on my
mind. The porker would love to have a friend in the garage, I am sure, and a four post lift would definitely make it easier to detail the wheels. Hmmmm.
acidfnord
PostPosted: Fri Oct 13, 2017 10:42 am    Post subject: Reply with quote
This is really useful - I have been laying awake worrying about the same - the guy who built our garage clearly had no plans ever to put a car in it!
How many cm, from side of the car to wall, do you think you need to open the door and get out?
Any views would be very helpful.
Cheers!
blackram
PostPosted: Fri Nov 03, 2017 10:04 am    Post subject: Reply with quote
What width is your garage at the car door opening point?
991.1 Carrera S Agate Grey
blackram
PostPosted: Sun Nov 12, 2017 5:19 pm    Post subject: Reply with quote
Garage finally renovated and car fitted perfectly. I can walk all round the car and my garage is 2.76m wide. Some before and after photos. To follow.....
 Filesize:  786.17 KB
 Viewed:  6394 Time(s)
blackram
PostPosted: Sun Nov 12, 2017 5:21 pm    Post subject: Reply with quote
Another pre-works shot!
 Filesize:  774.79 KB
 Viewed:  6390 Time(s)
blackram
PostPosted: Sun Nov 12, 2017 5:26 pm    Post subject: Reply with quote
Ply-boarded and painted ceiling, new LED 600mm panels (very bright), painted walls, new electric roller door and new UPVC back door. New loft ladder to access mezzanine floor. Ecotile K490 tiled floor. Porsche tailor-made blind. Very pleased and the car fitted perfectly!
 Filesize:  1.81 MB
 Viewed:  6388 Time(s)
blackram
PostPosted: Sun Nov 12, 2017 5:28 pm    Post subject: Reply with quote
Yes I need three more tiles, car now home for good!
 Filesize:  751.11 KB
 Viewed:  6385 Time(s)
G2
PostPosted: Sun Nov 12, 2017 6:43 pm    Post subject: Reply with quote
Lukem
PostPosted: Sun Nov 12, 2017 7:02 pm    Post subject: Reply with quote
The old trick of a tennis ball hanging from the ceiling helps. New build garage. A little bit tight.
 Filesize:  741.77 KB
 Viewed:  6338 Time(s)
 Filesize:  858.76 KB
 Filesize:  1.04 MB
blackram
PostPosted: Sun Nov 12, 2017 7:41 pm    Post subject: Reply with quote
What is your side clearance like? Easy in and out?
Lukem
PostPosted: Mon Nov 13, 2017 6:35 pm    Post subject: Reply with quote
It's a little tight through the door but 2.92m width once in. I only put it in the garage a couple of times a week or if the weather is bad, I've got alot of trees around the drive. After a couple of times it's easy. Also stuck a sponge to the wall so I can open the door without worry.
markz86
PostPosted: Tue Nov 14, 2017 7:50 am    Post subject: Reply with quote
I have about 15cm of clearance from the rear bumper to the wall on mine. I chose to cut a wooden block to size and simply reverse until the rear wheels touch it - that way even if I approach a little too fast it's very unlikely to hit the wall
Current:
991.1 C4S Aerokit Manual - Carrara White
958 Cayenne Diesel - Carrara White
Previous:
991.1 C2 Manual - Basalt Black
957 GTS - Basalt Black
997.2 C2 Manual - Arctic Silver
997.2 C2 Manual - Basalt Black
997.2 C2 Manual - Guards Red
weejimmy
PostPosted: Wed Nov 15, 2017 5:29 pm    Post subject: Reply with quote
Ditto. Except I drive in nose first. I like the reassurance of the front tyres nudging up against the wood over a Tennis ball touching the windscreen!
