997 : 2004- 87
996 : 1997-2005 45
Boxster : 1997- 14
Cayman : 2005- 14
Macan : 2014- 0
Endex
PostPosted: Thu Aug 10, 2017 10:59 am    Post subject: How reliable is PCM2 in the 997.1? Reply with quote
What are feelings on PCM2 reliability? Read a lot of threads on here and elsewhere on fault messages and general issues as they age. If so, what are the alternatives?
Porsche 997.1 C4S, Manual
Martian
2007 Porsche 997 Turbo
PostPosted: Thu Aug 10, 2017 11:38 am    Post subject: Reply with quote
My PCM2.1 unit is 10 years old, no issues.
Obviously now outdated but I live with it whilst it's working!
Endex
PostPosted: Thu Aug 10, 2017 11:49 am    Post subject: Reply with quote
Good to hear Martian. I can live with outdated because it sort of matches me!!
Carrerascott
PostPosted: Thu Aug 10, 2017 3:29 pm    Post subject: Reply with quote
Mine is nearly 13 years old and no issues to date.
Luck of the draw I suppose Dont know
997 Carrera S Gen1
resigner
PostPosted: Thu Aug 10, 2017 5:34 pm    Post subject: Reply with quote
PCM 2.1 was fine when I had it, the problem is usually the amp which means you get no bass.
The satnav alone is awful, the way you get an ipod wworking with it and functionality thereafter is useless, so I upgraded, but toying with upgrading again to something with full android auto and DAB radio......
PostPosted: Thu Aug 10, 2017 5:45 pm    Post subject: Reply with quote
Before I fitted an alpine unit my pcm2.1 worked fine very very outdated but worked and with the ipod and bluetooth units added did the job for me ok . as Resigner it was my non Bose Amp that failed, loss of Bass. fitted a rainbow beats2 amp and was then pretty much better than Bose Thumb
Endex
PostPosted: Thu Aug 10, 2017 5:59 pm    Post subject: Reply with quote
Cheers fellas - looks like best plan is to use as is and upgrade if I have failure downstream.
PostPosted: Thu Aug 10, 2017 6:00 pm    Post subject: Reply with quote
The CD drive can pack up and occasionaly they cause a battery drain but over all they last pretty well .. most are changed as they are old i would have thought .
Nav maps can be updated but its expensive via Porsche .
Endex
PostPosted: Thu Aug 10, 2017 6:08 pm    Post subject: Reply with quote
Cheers Demort - my car had a PCM fault but specialist identified an issue with the SIM card module and blue tooth fibre connector both of which have been replaced and new software loaded at Porsche under warranty. Guess as I said, I'll keep using until it fails then upgrade.
