-- 997 -- said:Phil 997 said::floor: :floor: I get the blame for everything. J sent FF a message explain whats happened see if they can send you a tip insert and sell your manual one on here or fleabay. They are very nice people at FF and I am sure they will try and help. The other option is to pick up a used manual mount and fit that and the FF insert. :thumb: :thumb: Iain you can come out from under that rock now mate :grin: :grin: :grin: :thumb:
I guess whoever at Porsche fitted that mount wouldnt ever expect it to cause an issue as they would just replace the mount and not fit an insert.
Hahahahahaha, no worries, im planning to get the correct bush and get to change it sometime, so ill hang on the the inserts and use them at a later time.
J
Sounds like a plan mate :thumb: is Iain still under that rock :whiteflag:
