997 : 2004- 78
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 20
Cayman : 2005- 11
ELA
PostPosted: Mon Mar 13, 2017 3:37 pm    Post subject: 996 / 997 owners beware Reply with quote
My car is a very clean 80 odd thousand mile early 996. The 996 and 997 have a reputation of being very resistant to rust with no known issues, or at least that was my opinion. Well today I removed the rear arch forward and lower plastic arch liners and was very happy to have removed 760gr of mud/stones in the process. However in the lower forward corner I found some rust and it appears I have got there just in time. Now my car is never really driven in anything but perfect weather; well at least for the 6 years I've owned it. So this is just a warning and request to please go out and remove these liners and check for rust/bubbling under the seam weld, this could just save you a small fortune in the near future in welding in new sills...
Should only take you about 2-3hours per side to remove, clean, rust treat (I use Fertan) then repaint and seal. I just thought I'd give you guys a heads up whilst I'm half way through rectifying mine.
Pics below
Remove these:
Here is my LH arch:
And RH side:
CLR996 1086kg bespoke design
Harv
PostPosted: Mon Mar 13, 2017 4:15 pm    Post subject: Reply with quote
Top work and good to get these potentially expensive issues out there. Prevention is much better than a cure
I need to remove my liners to address some cracked sill covers so will take the opportunity to have a clean and wax up
Y2K
PostPosted: Mon Mar 13, 2017 4:57 pm    Post subject: Reply with quote
Good stuff! Will add this to my bi-annual task list. Cheers!
2005 996 GT3 mk2
1999 Integra DC2
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Mon Mar 13, 2017 5:00 pm    Post subject: Reply with quote
Good plan... I know mine is going just a bit where stones have chipped the front wheel arch edge, didn't think to check the back.
At 109k miles I probably don't want to as that boat has likely already sailed! Sad
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Mon Mar 13, 2017 5:15 pm    Post subject: Reply with quote
At the age they are now this is the main place I have seen any rust building, around the rear arches. I have treated and repainted my N/S rear arch lip and we are lucky that it's an easy to access place and not particularly hidden once checked.
It's good to be aware for the future as it's easier to nip it in the bud now than have to start cutting and welding in a few years.
Robertb
PostPosted: Mon Mar 13, 2017 5:20 pm    Post subject: Reply with quote
Of the 2 hrs, how long is spent disassembling/reassembling?
steve r
PostPosted: Wed Mar 15, 2017 11:08 am    Post subject: Reply with quote
I removed a similar amount from mine & my friends 2003 cars while changing the suspension. Both cars have the aero kit skirts which held the dirt in. I used an airline to blast all of the dirt out. A lot of dirt collects behind the plastic arch liners, these were all cleaned too.
40th Anniversary
steve1
2002 Porsche 996 Carrera 2
PostPosted: Fri Mar 17, 2017 9:24 am    Post subject: Reply with quote
Did you have any issues with the fixing screws on removal, and what type screw heads are they
2002 996 C2 cab red
Captain Lockheed
PostPosted: Fri Mar 17, 2017 9:42 am    Post subject: Reply with quote
Great stuff.
997.1 C2S Tip 2005
Saving for a 993.
FRZ 911
2007 Porsche 997 Carrera 4S
PostPosted: Fri Mar 17, 2017 9:58 am    Post subject: Reply with quote
Captain Lockheed wrote:
Great stuff.
Agree and I'll be taking a look myself. Thumb
997.1 C4S Meteor Grey Manual
Porschekit
PostPosted: Fri Mar 17, 2017 3:30 pm    Post subject: Reply with quote
FRZ......my car is the same as your except it's an 09 plate......let me know what muck you find in your 997.1 and it will determine if I do the same this summer...thanks. Thumb
Alam
PostPosted: Fri Mar 17, 2017 3:36 pm    Post subject: Reply with quote
This is also true of most of the aircooled cars, arch liners seemed to be an after thought for the earlier cars. As a result lots of muck and debris build up leading to rust.
I am surprised thought for a 997 to still have similar problems... Oh well.
Dont know
K
90 Porsche 964 CSR (RPM Technik)
95 Porsche 993 C4s
96 Porsche 993 C2s
Marky911
Watkins Glen
PostPosted: Fri Mar 17, 2017 3:50 pm    Post subject: Reply with quote
Good thread Rich!
Will have a good poke about under mine once the weather gets a bit warmer.
I'm going to contact these guys next year when I get onto the cosmetics.
http://www.cumbriacarstorage.co.uk/corrosion_protection.html
steve r
PostPosted: Fri Mar 17, 2017 4:51 pm    Post subject: Reply with quote
They are a mix of Torx screws (T25 & T27 i think) and plastic nuts that hold the liners on. You might need to replace a few of the plastic nuts.
40th Anniversary
chriscoates81
PostPosted: Sat Mar 18, 2017 7:21 am    Post subject: Reply with quote
I'm guessing the crap only builds up along the rear of the arches. I'm surprised that much has got on.
Old:1999 Carrera 2 3.4 in ocean blue with a savanna interior.
New:2002 Turbo in silver with black interior - the smile machine
Griffter
PostPosted: Sat Mar 18, 2017 9:11 am    Post subject: Reply with quote
When I cleaned out behind the liners on my 996.1 last year, the most muck was behind the small liner section at the lower, outer forward section of the rear arches - first pic above.
ELA
PostPosted: Sat Mar 18, 2017 9:35 am    Post subject: Reply with quote
Exactly Griffter, have now finished mine so there'll be no further issues here Wink
Harv
PostPosted: Sun Mar 19, 2017 8:40 pm    Post subject: Reply with quote
Tackled my liners and sills today (C4S) and can say this is most definitely a worthwhile task.
The C4S/Turbo uses a different sill due to the wide body config which features plastic sill extensions that run the length of the body along the side. These where removed and I found practically nothing in those seams (they are very narrow) but at the sill ends where there are return lips it was the same story as ELA.
On my car there's also quite a bit of debris buildup behind the wheel arch liners on the wheel well walls.
I did find a small patch of rust drivers side, 12 o'clock on the double skin section where the outer rear wing and inner wheel arch meet and are spot welded together so this will get special attention, anti rust, seam sealer before clear waxoyl.
chriscoates81
PostPosted: Mon Mar 20, 2017 6:18 am    Post subject: Reply with quote
Is it worth drilling a small hole in the bottom of the liner for any moisture to drain out? Also I had the task of swapping from winters to summers this weekend, and I just can see how anything can get behind the wheel arch liners, all the joints I could see were overlapping and tight against each other.
Avon
PostPosted: Sat Mar 25, 2017 11:04 am    Post subject: Reply with quote
Thanks for this tip, i just cleared a truly sobering amount of crud out of these areas. The drivers side was much worse than the LHS. Fortunately no rust, maybe the dark blue colour helps it keep dry by getting warmer than white / silver...
