997 : 2004- 69
Boxster : 1997- 31
MarkGolf
PostPosted: Sun Aug 07, 2016 1:32 pm    Post subject: Help - rear top mounts Reply with quote
I'm in the middle of fitting my rear H&R coilovers and I've just removed the drivers rear and swapped the top mount over to find it doesn't leave enough of the threaded top part of the piston to poke through in order to get the top nut on it....
What's going on?? Disappointed as something clearly isn't right.
Current fleet
1991 964 Carrera
2005 997 Carrera S
2008 957 Cayenne GTS
2003 Boxster 2.7
1994 Eunos Roadster S Special Turbo 270bhp!
1991 Mercedes 500SL
1979 Mercedes 280e
1995 VW Golf VR6 3.0
PostPosted: Sun Aug 07, 2016 4:38 pm    Post subject: Reply with quote
Not my area of expertise but this is all i have ..
I assume you mean with the coil compressed with spring compressors the actual shaft thread that goes through the top mounts is not long enough ..
I think there are 2 types of rear top mount so perhaps you have the wrong shocks for the mounts or visa versa .
Gazc2
Watkins Glen
PostPosted: Sun Aug 07, 2016 5:27 pm    Post subject: Reply with quote
There are two different types of rear shocks for the 964 for the early and later cars you need to check you have the right coilovers
2007 997 Turbo & 924s Restored
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
MarkGolf
PostPosted: Sun Aug 07, 2016 6:32 pm    Post subject: Reply with quote
Balls, you're both gang on, I have the early style top mounts, the coil overs are for the newer type.
Please tell me I can just use the newer style top mounts, has anyone got some laying around?
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
Gazc2
Watkins Glen
PostPosted: Sun Aug 07, 2016 7:30 pm    Post subject: Reply with quote
Mark
Sorry to be the bearer of bad news however I`m pretty sure the top mounts are not interchangeable if you have the wrong coilover kit you need them changed for the right ones
Gaz
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
MarkGolf
PostPosted: Sun Aug 07, 2016 9:40 pm    Post subject: Reply with quote
Oh no!
So is there a difference to the turrets between early and later cars then?
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
MarkGolf
PostPosted: Sun Aug 07, 2016 9:57 pm    Post subject: Reply with quote
I think I've got it, I need these adapters with a later spec mount...
http://www.ebay.com/itm/Porsche-911-964-1989-1990-Rear-Shock-Adapter-Plates-for-Late-Style-Shocks-/252308158331
Seems a bit of a bodge but I've had the coilovers sitting around for 6 months and the fronts are fitted so no going back unless someone wants to swap my lates for earlies, h&r...
bye
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
paul284pt
PostPosted: Mon Aug 08, 2016 1:45 pm    Post subject: Reply with quote
Hi Mark,
I had to have Redline Racing manufacture adapters for my rear (Rennline) top mounts so you're not alone. bye
Cheers,
Paul
1980 - 84 924 Turbo with mods. (ex Tony Dron - 12th at Le Mans 1980 with works 924 Carrera Turbo).
1984 - 89 911 SC (1982)
1989 - 93 911 Carrera Sport (1989)
2010 - 964 Carrera 2 (1990) Redtek 3.8RSR
2012 - 14 Porsche Cayenne (2012)
2015 - 17 Porsche Cayenne Diesel S (2015)
2017 - 18 Macan Turbo Performance Package (2017)
2018 - 991.2 Carrera 4 GTS (2018)
crash7
PostPosted: Wed Aug 10, 2016 9:24 am    Post subject: Reply with quote
This may be of use?
http://rennlist.com/forums/964-forum...-adapters.html
MarkGolf
PostPosted: Thu Aug 11, 2016 9:59 am    Post subject: Reply with quote
Thanks guys, I'm reluctant to remove the kit and sell on to then go and buy another kit suited to the early 964, what a pain. So it looks like I'm going to get a hold of some late top mounts along with those US adapters with £50 delivery charge, doh!
Thanks for the help.
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
