Roro
Sebring
- Joined
- 1 Oct 2010
- Messages
- 7,498
Excellent tone, aggressive and snarly. This was the original pipe that H&S created and so was the template for all others they since fabricated. As such it's a bit of a hack as they were perfecting the design, you may need to adjust / reposition the holes on your OEM tips in order to fit. Your OEM tips may sit slightly (maybe a cm) off-centre once fitted. Not really noticeable, and this didn't bother me in the several years I had this fitted to my car. Have now moved on to a different exhaust system and so am having a garage clear out
The sound is intoxicating, this pipe really livens up the driving experience. If you do trackdays then you will be too loud for most circuits and will need trackday silencers. With this fitted you will worst case fail 105 static test, at best you'll scrape through if you smile and flutter your eyelids. Avoid tracks with 105 or lower static tests and you'll be fine, if you know where the drive by monitors are
£220 + delivery
£220 + delivery
