Private Pike
- Joined
- 31 Dec 2020
- Messages
- 90
We have bought a 993 C2 Cab 1996 and would like to know what would need servicing / inspection after only doing 4000km since the last service in late 2018
The vehicle has been used sparingly over the last 2.5 years
I've listed below what has been changed from the invoices we have and would welcome advise, I've been to a Porsche dealership today to ask the the same question and would like to compare, thanks
Service
Drive shaft fitted
Power steering pressure - presume fluid change
Torque joint x 2 - not stated where
Oil filter
Oil change
Air filter
4 x Michelin Pilot Sport - tread ok
A/C recharge
Geometry
Gearbox fluid checked, DEXTRON III added 1 litre - not drained up but topped up ?
Idle speed adjustment hoses x 2
idle valve cleaning and hose replacement
Looking at the history I can't see spark plugs done in the last 15000km or belts a part from the AC belt which is new
Brakes / Discs are fine and clutch was replaced 60000km no issues here
Thanks for reading
Service
Drive shaft fitted
Oil filter
Oil change
Air filter
A/C recharge
Geometry
Thanks for reading
