Hi guys,
The 987 I picked up in the summer has a very sloppy shift. It changes gear fine, but there is a lot of play in the mechanism. It's a 2010 2.9 6 speed.
I have a SSK which Alex from here machined up for me, and has no play in the shift mechanism at all. Any play between the cable ends and the actual gear selector arms on the gearbox is minimal (is there a technical name for these parts?).
As you can see from the video, even when in gear the gearknob has a lot of side-side, and front-back play. You can see in the video how the gear selector arms of the gearbox are wobbling as the shifter is wiggled whilst in gear.
Without knowing much about these, I would assume that they run on bushes which have worn out. I have read lots about play in the shift mechanism at the gearknob-mechanism end, and in the cable ends, but not about this.
It has standard cables (I'll get numeric if they break during my ownership), but that shouldn't affect this.
Any thoughts? What are my options? Looks like it would be a right PITA to tinker and take any of this apart without removing the gearbox.
Thanks! (I suggest opening the video in youtube to watch fullscreen as its hard to see exactly whats happening here).
https://youtu.be/yrmPCgDtiAE
