My official battery is only two years old and has given up. Just won't hold any charge and my charger indicates that the battery is faulty.
So, now the tricky part of replacing the battery!
I have my official battery replacement ready to go (£200!!!!) and I've got enough power to pop the bonnet, but the power's low as the alarm occasionally goes off (ie. the voltage has dropped below a certain level).
Reading the instructions pasted below, the suggestion is leave the key in position 1 (because of the extreme loud alarm)......and as I'm replacing the battery in the garage the noise will be even worse!!
However, the manual clearly "switch off engine and all electrical loads".
The manual also says removing negative first and then when installing the battery connect positive first (danger of short circuit).
GT4 wrote:
To change the battery:
Put the key in the ignition and turn to "1".
That way you won't be deafened by the alarm module (cunningly placed by the battery, under the front bonnet which is also perfectly designed to channel all that siren goodness to your ear drums).
Disconnect negative first.
Swap batteries
Reconnect negative last.
Don't forget to reconnect the acid vapour overflow pipe.
If you aren't under warranty to OPC, get yourself a nice big capacity battery for a decent spark, cranking ability and general ability to last longer without use.
Get a Bosch or Varta (it is a rebadged Bosch, but should be cheaper, obviously check Bosch deals too)
315*175*175 mm
85 Ah and 800 CCA
FIVE year warrany
Varta Silver 585 200 080 (short code F18) - circa £90
Bosch Silver 0092 S5 010 (short code S5 010)
Next time it goes, I'll get the Bosch Silver as my car will be out of OPC warranty.
Swap batteries
315*175*175 mm
85 Ah and 800 CCA
FIVE year warrany
