911tom said:Thanks Ken. Really appreciate the advice. :thumbs: Do you think my excessive IDC is 100% map related or is it potentially to do with me upgrading intercoolers, pipework, plenum and throttle body?
911tom said:Thanks again Ken. This all makes sense and sensibly I need to decide on where I am going with all this. For now I think I will go back a step with the mods in the hope that my IDC's will drop.
ChrisT70 said:this is why Ken at 9e would be my man if i was a turbo owner!
wizard993 said:911tom said:Thanks again Ken. This all makes sense and sensibly I need to decide on where I am going with all this. For now I think I will go back a step with the mods in the hope that my IDC's will drop.
What specific exhaust and cats, re 100 or 200 cell ?)are you running and what waste gate actuator pressures are you seeng before the gates open? If/when you changed the exhaust did you replace the oxy sensors or just re-use the old ones?
Has the ecu been modded, (when?) and/by whom?
What are the fuel trim readings at 1700rpm(essential that you get his data)
Are you running Tesco or Shells finest in it?
Std or high capacity fuel pump fitted (normally high capacity required over 570bhp)....along with bigger injectors.
1.2/1.3 peak bar is about right for 600bhp car so your not bleeding boost pressure.
996ttalot said:Tom
Your set point is not a 1.1 bar map - look at your datalog - you don't specify boost - you specify load which equates to boost.
The most likely reason is now you have no boost leaks (assuming) this is true, that you are getting what the map is giving you. Maybe when it was tuned it was not boost leak free. I see loads of cars where when it was tuned,
They couldn't get the boost up to the right level and therefore raise the target load to pull the boost up. Then subsequently when for example the boost leak is resolved, hey presto the car gives more boost. More boost means you need more injector.
I doubt removing the new parts will make any difference to your IDC - it is not going to change what is in the dme. If you don't want to fix the tune, see if you can lower the cracking pressures sufficiently so that it will bleed the boost and therefore lower your actual, even if the target is higher.
911tom said:wizard993 said:911tom said:Thanks again Ken. This all makes sense and sensibly I need to decide on where I am going with all this. For now I think I will go back a step with the mods in the hope that my IDC's will drop.
My exhaust is the 9e switchable. 100cel. Reused the old sensors but they are only 2 years old. Both waste gates start to crack around 0.8.
Ecu mapped by Dms two years ago.
Thanks I'll log fuel trims next.
Always shell vpower or bp ultimate.
Standard pump and injectors. Have a feeling this will soon change!
I think Ken has hit the nail as usual in that the maf fault appears around 30% throttle at 3000rpm. Therefore I think it is a tuning issue with the bigger throttle body. I believe the injectors are maxed anyway and me adding more air has made this worse. Really I think I need injectors, pump and a tune!
My only concern is I may have to bring the van to vmax or keep a really close eye on the afr's
