Hello All,
What I hoped to be a relatively easy job of replacing the engine mounts, that were still the OE parts, has turned into a PITA!
After using heat copious amounts of penetrating spray and effort the elation of getting the main bolt off the underside quickly turned to horror when the rear passenger side 13mm hex bolt snapped after only coming out a few mm.
So far I think my best bet is to drill it out from the underneath, I have nothing sticking out to attach too and cannot get an easy out over it due to the coolant tank being in the way.
More of a rant than anything but any advice if someone has experienced it is appreciated!
