ballcock said:
Another 993/G Wagener! :thumb:
I think we may have a few mutual friends in the G world.
Is your rally G a 460?
Its a 460 chassis/ body being converted to run on G55 axles/ transfer box (the 460 VG080 transfer box in addition to being pt 4wd is only rated at 800Nm) with a set of RCV axles to complete.
The project started out with somewhat modest ambitions to just transplant the 606, but has grown into a bit of a monster with not only a full engine build (gas flowed head, uprated springs, valves, cams done by Ric Wood, modified Holset Turbo, rebuilt Myna-Diesel racing pump with bigger plungers etc etc), but also significant changes to chassis geometry and suspension setup (the CRC link, dual shock setup, adjustable caster etc) and of course the gearbox transplant which required the custom flywheel to work... what was meant to be a couple of month's work has now been 18!
It will go well once its done though!
I must refrain from the temptation to do too much to the 993 in the meantime (or my W123 AMG estate that is also awaiting a complete strip/ rebuild and interior change!).
I've got the 993 in with the guys at AutoBodyTechnic in Slough to do the cosmetic stuff. Front end is being resprayed, new sets of panel and door seals all around, front screen out to do the corrosion (of which there is very little but it needed to be done) and replacing front lenses with clear Porsche originals (and a full set of LEDs/ HIDs from Bergville FX)
The interior is pretty good on the whole - I've ordered a couple of new switches, a new set of front carpets, ignition rose and so on.. The handbrake has a mark on it, but as you say expensive so will probably wait. The main item I have to locate now is a child seat (Porsche Prince most likely as I think not a lot else fits)
I have also been a bit indulgent with the new Porsche Classic radio (which is painfully expensive but looks much better than the neon and plastic of anything else I can find) and a set of JL Audio speakers all round.
I've been pretty distracted with work over the past few weeks so haven't thought about it much but I'm now quite excited to be picking it up
