Hi All,
I'm looking to get a few bits sorted on the 996 4S. There is a leak on the front diff which does need sorting. I also have a leak from the RMS/IMS so will get this done and will inspect the IMS, my intention is if ok to leave and remove the outer case.
Question is with the gearbox dropped should there be any other preventative stuff I should consider? Clutch was 20k miles ago just before I had it. I'll look to replace the brake pipes.
Anything else I should consider please....?
Does anyone know what sort of cost I'm looking at for the above works, I'm allowing £2k. Is that enough or a bit more?
It seems never ending, I'm also going to sort a small amount of rust on the rear arches, replace the cracked side skirt and sort the sagging roof liner.
