No with a 295 or 305 you’d run a 235 up front.There maybe, you need to keep the rolling circumferences within a tolerance so you may have to change the fronts to keep the ratio the same front to back.
If your factory wheels run a a front 235/35/19 8J or 8.5J with a 295/30/19 11J on the rear, If you go to a 305/30/19 11J or 11.5J rear you will increase rolling circumference by 3mm.
You could change the fronts to a 245/34/19 which will add 3.5mm to the front so only 0.5mm which I'd imagine to be acceptable. You can play around on:
Alloy Wheel & Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
Alloy Wheel & tyre fitment calculator - it calculates inset, poke, speedo error, tyre stretch and loads more.www.willtheyfit.com
