aaronbailey
- Joined
- 25 Oct 2020
- Messages
- 1
I noticed a small deposit on the garage floor at about the position of the front of the gearbox and towards the nearside, seemed to be like a light oil!!
I have now put it on stands and I can see a drop of liquid on an aluminium pipe which comes from the top of the coolant header tank and which eventually disappears forwards. Pipe dia. approx 1/2 inch presumably a vent pipe?
Can only be a coolant leak but very minor at this stage. No obvious damage to the pipe but it must be pinholed somewhere.
I intend to pressurise the system to 20 psi to see if I can spot the source and as it looks like a very awkward job to replace the entire aluminium section, I was considering replacing only the leaking piece with some hose and clips.
Has anyone replaced this pipe in situ?
Best regards.
Best regards.
